Any way to get d150 drop spindles?
Old Mar 2, 2008 | 09:45 PM
  #111
84 Ram's Avatar
84 Ram
Default RE: Any way to get d150 drop spindles?
Mocked up my spindles and springs today and wouldn't you know it Chassis Tech sent me the wrong springs. The springs are 3.5" to long so they actually raised my truck even with the drop spindles. Once I get that figured out I will start documenting with pictures and post them on here to help everyone else.
Old Mar 3, 2008 | 07:26 PM
  #112
lugnuts's Avatar
lugnuts
ORIGINAL: 84 Ram
Finally got my spindles in today. Which way are you going on the tie rod ends?
Old Mar 3, 2008 | 07:35 PM
  #113
84 Ram's Avatar
84 Ram
I am probably going to go in from the bottom I know that it might mess with the bump steer but I have seen it done and the angle don't look that bad.
Old Mar 3, 2008 | 07:57 PM
  #114
Rampant 150's Avatar
Rampant 150
Are the tie-rod holes on the spindle tapered one way, or are they even, like a tube. Just wondering, I've seen them mounted from the top. Would that mean they had to be machined out in the opposite direction?[align=right][/align][align=right][/align]
Old Mar 3, 2008 | 07:58 PM
  #115
lugnuts's Avatar
lugnuts
What about the different size holes? Come up with an end that'll fit? Another reason I was wanting to do the rack install. I'd like to duplicate the Dak's factory angles, and just use Dak rod ends. Lots of extra work though.
Old Mar 3, 2008 | 08:17 PM
  #116
84 Ram's Avatar
84 Ram
The Dak spindles that have the tie rod in from the top have been machined. The spindles are tapered from the bottom. As for what tie rod will fit the spindle without machining and will thread into our tubes I have read that tie rods from a 79 B-100 van will fit or so I have read I have yett to try it so I can't promise anything.
Old Mar 3, 2008 | 08:28 PM
  #117
Rampant 150
Why not machine them to fit stock tie rods from the top?
Old Mar 3, 2008 | 08:37 PM
  #118
84 Ram's Avatar
84 Ram
I may I havent got that far yet I am still trying to figure my springs out Chassis Tech has sent me the wrong springs and they are trying to say it is the spindles.
  #119
lugnuts's Avatar
lugnuts
Yeah I read that too. My old truck alreadyskitters around on bumps and such, would be nice to correct it. I have all the factory P.S. stuff off of the derelict '88. Would save alot of B.S. to just go that route if the tie rod angles don't cause the same bumpsteer it already has. Everybody says they drive fine though. Alot of what I'm feeling in the strg.wheel is because of the manual box, and no sway bar induced body roll.The shorter steering arms would make it harder to turn at low speeds with the manual. It's already a workout in a parking lot.
Old Mar 3, 2008 | 11:55 PM
  #120
lugnuts's Avatar
lugnuts
ORIGINAL: 84 Ram
The springs are 3.5 inches longer than stk? And it's supposed to be the spindles? Now how the hell do they figure that one?
