Any way to get d150 drop spindles?
Old Feb 19, 2008 | 09:18 PM
  #61
lugnuts's Avatar
lugnuts
Default RE: Any way to get d150 drop spindles?
Haven't checked it myself, but have read a post that says to use the bigger '83-'93. Surely between all of us we can come up with something that'll work like it should, and the main thing, safely.
Old Feb 20, 2008 | 09:04 AM
  #62
turbododgepirate's Avatar
turbododgepirate
ORIGINAL: 84 Ram
I am going to be ordering my spindles and springs tomorrow so when you figure out a good way to mount the tie rods be sure to post it. If I find a good method I will do the same. Has anyone researched the differences in the bearing sizes 72-83 is supposed to have one size bearing and 83-93 is suposed to be different.
Yes, if you read through the thread on ramchargercentral, I believe that if you are going to use the dakot adrop spindles on a older first gen ram that you need to mill it for the 72-83 bearings. It just seems like it would make more sense to get the newer hardware and not screw wiht it more than necessary.
Old Feb 20, 2008 | 07:24 PM
  #63
Rampant 150's Avatar
Rampant 150
Yeah, I heard that there is a bearing difference too. Apparently if you are putting the spindles on a pre 83 ram, you either need to do some machining to get the bearing to fit, or you can switch to a 84* and up hub. The swap would be much easier and cost effective, but will give you a different bolt pattern (5x5.5)
*I dont know if 84 is the year change.
Old Feb 20, 2008 | 08:48 PM
  #64
lugnuts's Avatar
lugnuts
'85, my '84 is 4 3/4 B.C. Dad's '85 was 5.5. Spindles should be here tomorrow. The rack thing is costing me sleep, I'm gonna price a rebuilt rack.Saw you guys on another site. Nice trucks. Mine hasn't had the dust washed off in a long time. Been sitting in the garage.[Yeah I know]Gotta get it presentable as possibleif we're gonna post how to's. [After I figure out how]lol.
Old Feb 20, 2008 | 09:18 PM
  #65
mrbelvedere's Avatar
mrbelvedere
in 84 was when they went to that stupid bolt patteren and the different bearing in the inside of the rotor they all still use the same outside bearing but 84 up they use a different inside and the dakota spindle uses the same big inside bearing
Old Feb 20, 2008 | 09:54 PM
  #66
84 Ram's Avatar
84 Ram
I just ordered my 2"drop spindles and 2" drop sprinps from Just Airbag It Wow their shipping is unreal high 82 dollars for Fed Ex four day shipping
Old Feb 20, 2008 | 10:32 PM
  #67
lugnuts's Avatar
lugnuts
ORIGINAL: mrbelvedere
Got '83 rotors on my '84, and they're 4 3/4. Got the wheels off the '83 on all four corners. The '83 was my previous hot rod till it got hit in the front. It lives on as a 3/4 ton after a frame swap from a '73!
Old Feb 20, 2008 | 10:37 PM
  #68
lugnuts's Avatar
lugnuts
[quote]ORIGINAL: 84 Ram
[/quote Mine wasn't but $43 bucks! [Which is bad enough]Where are you?
Old Feb 20, 2008 | 11:37 PM
  #69
Rampant 150
Found some 88-98 chev shackles in truckin for $50. I'll see if I can get them shipped for cheap.
Old Feb 21, 2008 | 01:14 AM
  #70
daomen4ever's Avatar
daomen4ever
hey guys, what kind of lowering shocks can i use and will 88-01 chevy drop hangers and shackles will work or can we use 94-01 ram drop hangers and shackles......
