1990 w 250
Old Dec 23, 2007 | 02:02 PM
07slt4x4's Avatar
07slt4x4
Default 1990 w 250
Hi i just got a 1990 dodge w250 it has a 318 auto p/locks and windows it has 130450 miles on it i paid $300 for it it needs the floor pan on the driver side it has a big hole in it is that a good price for the truck and how can i fix the floor pans it runs like new i just dont know about the the body work this is the only spot that is real bad was this a good deal or did i get riped off thanks any info would be great thanks
Old Dec 23, 2007 | 04:17 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: 1990 w 250
check the wreckin yard for a floor pan section.
I am not sure if sections are otherwise sold.
otherwise a piece of hvy sheet metal and weld it in after you cut out the rotten area.
Old Dec 23, 2007 | 04:38 PM
moparborn's Avatar
moparborn
A 1990 4wd for $300,hows the rear wheel wells are they rotting out.
I think you got a good deal,but then again I'm mopar born and raised.
Repair panels are available,www.showcars-bodyparts.com.
Old Dec 23, 2007 | 07:17 PM
07slt4x4's Avatar
07slt4x4
ORIGINAL: moparborn
No the only thing that is roted out is the driver side floor pan and some minor rust but manly the floor pan it runs good and it gose right in to 4 wheel dr like a charm the body is some what banged up but not bad
Old Dec 23, 2007 | 11:20 PM
PushnFords's Avatar
PushnFords
I'd say you got a good deal. I paid $400 for my '81 W150. It ran but needed tires and about $500 worth of misc stuff. Has a heavy duty flatbed with 5th wheel hitch and heavy rear springs...but the cab is shot from being laid on its side. I'm buying a parts truck for $200 and will swap the body over. Sounds like you got a better truck than I did.
Derek
Old Dec 24, 2007 | 01:15 PM
rtaylor's Avatar
rtaylor
If its an 8 lug with Dana 60s front and rear you really got a good deal!!! Either way you did not go wrong for 300 bucks!! Floor pans are easy to fix, you can go the replacement route or cut the rot out and patch it with a piece of galvanized shaped and riveted in......just be sure to put some sealer around the seam to keep water out, if you have a rubber mat or carpet no one will ever see the repair anyway..........the replacement is a bit more involved with some welding
