traction bars
Old Jan 23, 2008 | 09:39 AM
300hp318's Avatar
300hp318
Default RE: traction bars
ahh that kind of sucks, i have a buddy who owns a four wheel drive shop. so i will do all my work in a garage. i have a dana 60 with 4:10's out of a 76 dodge 3/4 ton do think that is a good replacement for the stock 8.25?
Old Jan 23, 2008 | 07:46 PM
moparborn's Avatar
moparborn
definatly a stronger axle,but it will need more hp to turn it,more weight,maybe do a little measuring to make sure a lot of modification is not needed as it may cost more than the effort.
Old Jan 24, 2008 | 01:19 PM
PushnFords's Avatar
PushnFords
ORIGINAL: 300hp318
i just got my 6 cylinder runiing right. had a bad fuel pump. now that i see the power the litle 6 puts out i can just imagine what a 318 will be like. I plan on lowering the back and tubbing it out for some 15x10 wheels and some 14 inch wide tires. Do you know what the stock 8.25 will handle, or should i run something different.
thanks
An inline six with a decent sized carb and intake/header can put out a lot of torque. I've only driven my '81 W150 and a friends '80s D150 that both had 318s with 2 barrels but both are dogs. Neither one is low mileage so that is part of it but still...
Derek
Old Jan 24, 2008 | 01:25 PM
300hp318's Avatar
300hp318
my 318 only has 20,000 miles on it since it was built crank, cam, pistons, head work, intake 4bbl. i dont think it will be a dog.
