Need help, 4x4 issue
Old Feb 11, 2008 | 12:36 PM
91ram4x4's Avatar
91ram4x4
Default Need help, 4x4 issue
First to say hi to everyone since i'm new here, second, I just bought a 91 dodge ram 318 tbi 4 speed tranny long wheel base. The 4x4 keeps kicking out of 4hi, it works fine in 4 low, but every 30 or so seconds in 4 hi it keeps jumping out and grinding, some of the times it has went right back in, a couple of times I had to throw it back into 2wd. Above the sunvisor it has instructions to put it in 4hi while "MOVING" so I guess it has the Ram-Trac t case in it? Any help on this would be nice. Thanks.
Old Feb 11, 2008 | 06:06 PM
Dodgeman707's Avatar
Dodgeman707
Default RE: Need help, 4x4 issue
i had the same problem. i put in drive and idle into 4h with a slow pull dont jerk and then goto nuetrel and quickly pull it into 4L should work
Old Feb 11, 2008 | 09:31 PM
91ram4x4's Avatar
91ram4x4
Thanks, i'll try that, I have no problems with 4l, just 4h, I have tried it moving, sitting, moving with the clutch in, and moving with the clutch out, nothing has worked yet.
Old Feb 11, 2008 | 09:55 PM
dakota772's Avatar
dakota772
Try changing from 2WD to 4high or 4low while the trans is in drive or neutral. I used to try to change from 2WD to 4high and it did the same thing that yours does. Also, check the fluid levels just in case.
Old Feb 12, 2008 | 06:06 AM
Chump's Avatar
Chump
If this is the NP205 trasnsfer case, the first thing I would do is drain and refill the transfer case fluid.
Second, you need to go thru your shifter linkage, tighten,adjust,replace worn/missing parts.
[IMG]local://upfiles/21718/9C9A11DE24374EDAA1B6E5869EC6BF6A.jpg[/IMG]
Old Feb 12, 2008 | 03:59 PM
91ram4x4's Avatar
91ram4x4
I will drain and refill as soon as I can get under the truck, it is raining right now. I tried the idle with a slow pull, same thing. It does not do it in 4 low at all. I do know the guy I bought it from just replaced a vacuum (switch?) item on the transfer case. The 4x4 was not working at all prior to that. I do not know what transfer case it has in it. I thought the truck was a W150 untill I went to get insurance today, vin number comes back as a w250?
Old Feb 12, 2008 | 06:06 PM
Chump's Avatar
Chump
ORIGINAL: 91ram4x4
W250 is a 3/4 Ton
The switch controls vacuum to the front axle vacuum actuator(motor) to engage or disengage it for 4WD.
[IMG]local://upfiles/21718/D4A3109DBAF64E469A5A9C6056159DB2.jpg[/IMG]
[IMG]local://upfiles/21718/74E0806E66294D98A5723902EF334094.jpg[/IMG]
Old Feb 13, 2008 | 08:17 AM
91ram4x4's Avatar
91ram4x4
Thanks, off topic some, would a 3/4 ton not have 6 or 8 lug nuts? Mine is a five lug front and rear. of course someone may have robbed the axels out of it at one time.
Old Feb 13, 2008 | 10:49 PM
91ram4x4's Avatar
91ram4x4
ORIGINAL: Chump
It is a 208 transfer case. Does that make a difference with what I should check?
