holley projection kit for 318
Old Feb 25, 2008 | 05:43 PM
power ram's Avatar
power ram
Default holley projection kit for 318
Bought an unopened complete holley projection kit for a 318 engine for around $100 @ a auto part swap.
I was thinking about installing it should my 89' dodge's computer fry.
But was wondering if i could just swap out throttle bodies without installing the holley computer etc till my dodge's computer fries. The current older holley throttle body right now needs cleaning/rebuilt(maybe even some new sensors needing to be replaced).
What should I do??
Old Feb 25, 2008 | 08:43 PM
moparborn's Avatar
moparborn
Default RE: holley projection kit for 318
I do not think your new throttlebody will work with stock computer.
Old Feb 25, 2008 | 08:45 PM
moparborn's Avatar
moparborn
If you consider selling it I would be interested in it.
Old Feb 25, 2008 | 11:25 PM
power ram's Avatar
power ram
Would it be possible to switch from fuel injection to carburator?? And or how hard/easy would it be to rebuild my old throttle body?
Old Feb 26, 2008 | 12:21 AM
lugnuts's Avatar
lugnuts
Yeah it's possible to go carbed, but why? A rebuilt T.B. would cost less than a conversion, unless you already have the carburated parts. I did away with the carb and went to factory '88 T.B.I. on my '86 4x4 Ramcharger. Vast improvement. No off camber flooding, no cold start woes, 3mpg better on gas. As for the Projection, like most aftermarket stuff, it uses G.M. sensors. I'll give you$101.50 Is your 'ol truck running pretty bad?
Old Feb 26, 2008 | 05:38 PM
power ram's Avatar
power ram
What all would i need to buy in order to rebuild it??
Old Feb 26, 2008 | 06:21 PM
moparborn's Avatar
moparborn
Either you can have the injectors cleaned or replace them(I would replace them),Use carb cleaner on the throttlebody,as far as cleaning/rebuilding thats about all you can do,maybe a new base gasket all the other parts pretty much work or don't.
Old Mar 8, 2008 | 05:26 PM
power ram's Avatar
power ram
any recommendations on what brand of injectors to install in it??
Old Mar 9, 2008 | 11:16 AM
moparborn's Avatar
moparborn
If you are considering other changes like adjustable regulator,chip,headers or?
oem part if staying stock,maybe venom if modifications are planned.
I ran venoms in my 93 daytona and was very satisfied.
You will need to check around for aftermarket parts availability.
Old Mar 9, 2008 | 11:33 AM
mrbelvedere's Avatar
mrbelvedere
it isent that hard to go to a carb and get rid of fuel injection get a used intake a and an msd setup and a carb and your there
