Radio Help
Old Mar 10, 2008 | 06:13 PM
Jacob1's Avatar
Jacob1
Default Radio Help
Ok, i am on my last whim and i am seriously thinking about taking this thing to a audio guy. The radio, i have found the colors that got to the rear speakers, so i am going to just get a box and use those. What wires provide the radio with power, ground, and ignition. I have one large light purple wire that is bigger than any of the others. I m thinking this is power. Could you guys offer any insight? Anyone know where there are is a diagram of this? I checked haynes and chiltons (1992-1997 truck,van) and neither say anything about the radio. Any suggestions?
Old Mar 10, 2008 | 06:59 PM
nemesis_SS's Avatar
nemesis_SS
Default RE: Radio Help
A Right Rear Spkr (-) Blue w/ White Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe
C Right Front Spkr (+) Purple
D Left Front Spkr (+) Dark Green
E Right Rear Spkr (+) Blue w/ Orange Stripe
F Left Rear Spkr (+) Brown w/ Blue Stripe
G Power Antenna/Amp White (use for Infinity Radio)
H +12 Volt Battery Wire Pink or Pink w/ White Stripe
I +12 Volt Ignition Wire Red w/ White Stripe
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe
M Left Front Spkr (-) Brown w/ Red Stripe
N No Wire
Metal Braid Or Plastic
if you have a black plug and a gray plug then starting with pin one on black plug each pin is a, then b, c, etc...
i found a picture. http://www.installdr.com/Harnesses/DCP-Wiring.pdf
try googling it
hope this helps
Old Mar 10, 2008 | 07:47 PM
84 Ram's Avatar
84 Ram
If I install a radio in a newer car or trunk and it has the factory connector still inplace I go to Wal-Mart and get a adapter so that I don't have to hack up any of the factory wiring harness plus there is no tracing down wires.
Old Mar 10, 2008 | 09:22 PM
Jacob1's Avatar
Jacob1
Well, some idiot thought it be night on Thanksgiving to try and steal the radio out of my truck and my neighbors. But e heard my neighbors 9mm fire past his *** and he dropped everything. But i don't think anyone used the plug to begin with when they put the radio in. The radio is a Durabrnd CD player/radio. Now there is a plug in he back of the radio with wires coming from it, the dash has just wires comingfrom it too, no plugs, so someone screwed up whenthey put it in to begin with. So the ones you lsited in post are the ones that should come from the dash, right? Becaus the purple listed as right front + is alot bigger than the rest of them. I also see you didn't list a batery negative (ground), the radio lista wire for that.
Coming out the radio plugs is:
Red ignition 12v+
Yellow battery 12v+
Black Chassis ground
Dark Blue remote turn-on
Gray- fr+
Gray/black- fr-
White- lf+
White/black-lf-
Violet- rr+
Violet/black- rr-
Green- lr+
Green/blacklr-
The chassis ground should just mount topiece of grounded metal, right? If so can i use a dash brace for it?
I am thinking of forgetting about the front speakers and just buyingone of those premade boxes and speakers from Wal-Mart for about 15 bucks.
Thank you all a bunch, without you guys i was looking at about 100 bucks labor only!!!!!!
Old Mar 10, 2008 | 09:29 PM
84 Ram's Avatar
84 Ram
You can ground the radio to most any metal in the truck. If you have a test light you can test your ground, put the alligator clip from the test light on the metal that you plan on grounding the stereo to then probe the test light into the 12 volt source if the light lights up then you have found a good ground.
Old Mar 11, 2008 | 11:59 AM
Jacob1's Avatar
Jacob1
Got it back in today, but it wouldn't play a CD and ept cutting out. So i removede it and played with wires whil it was on. Now it works guess it just needed soem time to gather itself up. I usd the little stud on the back ofr adio with a nuton it for the ground.
Old Mar 11, 2008 | 04:22 PM
nemesis_SS's Avatar
nemesis_SS
was the wire plan that i sent you correct? (im gonna be pulling my won apart soon)
Old Mar 11, 2008 | 06:18 PM
Jacob1's Avatar
Jacob1
Yeah, just make sure to disconnect battery or sparks will fly. The attachment though had the wrong listings on the "most newer radio" wire/color list. But the colors in the post were dead on.
