91 w150 4X4 brakes
Old Dec 14, 2008 | 01:08 PM
150Dodge's Avatar
150Dodge
Default 91 w150 4X4 brakes
well last thursday i went and got 2 new front rotors and pads, and i got 2 new shoes and wheel cylinders for the back, about $200-210, i got the front all done (took all day saturday), the hardest part was removing the old rotor and the hub it took about an hour for the first one, trying to figure out how we could get it apart, the problem is the back trying to get the old drums off, tryed pb blaster and a hammer and that didnt do it, i think mabe the old shoes have worn a bit into the drums so thats why they wont come off, or they are just rusted on there really bad, anyone got any easy way i could get them off with out renting a wheel puller?, thanks
Old Dec 14, 2008 | 02:26 PM
moparborn's Avatar
moparborn
Did you remove the oval rubber plug and adjust the brakes in off the drum,if not start there,then spray around the hub with wd40 or?,then hit the drum around the hub with a hammer,don't hit the studs.
Old Dec 14, 2008 | 08:38 PM
150Dodge's Avatar
150Dodge
i didnt try the adjuster yet, mabe tommorow, to many cars in garage, got my dads cop car, my brothers mustang, my dads 79 pontiac and then everyone is fighting over the last spot, my brothers got to put his new 5inch exhaust on tonight and tommorow morning, so mabe after that i will try, but even still shouldnt the drum be able to wiggle some even if it was cause the shoes wore into it?
Old Dec 15, 2008 | 11:22 AM
nemesis_SS's Avatar
nemesis_SS
sounds like a big garage. lucky.
Old Dec 15, 2008 | 12:06 PM
1996Ram318's Avatar
1996Ram318
Do you have the emergancy brake engaged? I have made that mistake before.
Old Dec 15, 2008 | 02:52 PM
150Dodge's Avatar
150Dodge
yeah its a big garage, got a spot in basement and a 3 car garage, the parking brake wont even go down, i know that doesnt work but, i can rotate the drums so i would assume the brake is off
Old Dec 15, 2008 | 04:18 PM
1996Ram318's Avatar
1996Ram318
I`d smack it with a bfh.
Old Dec 15, 2008 | 06:44 PM
lugnuts's Avatar
lugnuts
If it's stuck in the center, I've had to heat the drum around the register on the axle,pry outwards on the drum and knock the hell out of it with a hammer.
If it's loose from the axle,but hung on the shoes,you'll have to back the adjusters off if they'll turn. If they're not rusted solid, bend a peice of stiff wire on the end to clear the adjuster and hold the adjuster lever off the ratchet wheel while you back 'em off.
If they won't turn you'll have to cut the retainer pins off with a chisel and pry the drum off shoes and all.
Old Dec 16, 2008 | 10:21 AM
150Dodge's Avatar
150Dodge
yeah when i get the chance to put the truck in the garage ill just try to beat the **** out of it with the biggest hammer i got and hope fully it wont fall of the jack and jack stands
Old Dec 19, 2008 | 12:58 PM
nemesis_SS's Avatar
nemesis_SS
li like transmission fluid to loosen stuff up. put it in an oil can and squirt all over everynow and then for a day or two. then go for a hammer.
