I figured it out
Old Dec 20, 2008 | 02:57 PM
power ram's Avatar
power ram
Thumbs up I figured it out
well I have that new tbi on my power ram and there was a gas leak. I thought it was the tbi all this time but, turns out one of the short metal fuel lines along the right valve cover going to the tbi has a pin hole leak and its dripping gas down on the manifiold. The drip gets bigger as the gas pedal is tapped. Where do I get a new metal fuel line??
Old Dec 20, 2008 | 04:52 PM
RedWing442's Avatar
RedWing442
Check your local auto parts store to see if they have an exact replacement, or do what I do, fabricate one from a generic metal fuel line. The TBI runs at about 12 p.s.i. so you don't have to worry about the pressure splitting it. You could even splice in some rubber fuel injection line if you want.
Old Dec 20, 2008 | 06:54 PM
power ram's Avatar
power ram
i wouldnt have to flare the ends?? just 5/16 fuel inject. line and a couple of fuel line clamps?
Old Dec 20, 2008 | 06:58 PM
nemesis_SS's Avatar
nemesis_SS
i bought an end flaring tool to make lines for my rambler.
but i use the tool more for othner stuff. once you have it brake and fuel line repair becomes so much less hassle. no more friggen around trying to get the right part or to not snap the one there. just cut out the bad piece, flare, and thread. worth the money
Old Dec 20, 2008 | 07:04 PM
power ram's Avatar
power ram
well the thing is im not making this a truck a daily driver. its only a farm truck for going 2 hrs up and back. The fuel line idea redwing had wouldnt work??
Old Dec 21, 2008 | 05:31 PM
power ram's Avatar
power ram
any body?? do i have to flare the ends where the new hose will go?
Old Dec 21, 2008 | 07:26 PM
nemesis_SS's Avatar
nemesis_SS
no he is correct you can use a solution like that. maye have to change the rubber after a while but no biggie. I just means the tool will get used ove rand over once you have it
Old Dec 21, 2008 | 10:08 PM
power ram's Avatar
power ram
so all i have to do is unhook that metal line, cut that small cracked section out and install a piece of 5/16" fuel inject. line and two small hose clamps. Did I miss anything?
Old Dec 22, 2008 | 01:58 AM
nemesis_SS's Avatar
nemesis_SS
well id use a rubber line
Old Dec 22, 2008 | 04:54 PM
power ram's Avatar
power ram
I thought thats what fuel injection rubber line was?
I was told use only that on a fuel injection setup and regular rubber line for carburetor.
