need help with wipers
Old Feb 5, 2009 | 02:05 PM
bubba232009's Avatar
bubba232009
Default need help with wipers
ok maybe im stpid but my wipers quit on me the other they had been working fine ishut them off and not 5 minutes later when i went to use them again they wont work the washer wont work either so i was thinkin it might be the switch but i wanted to know if anybody else has had this problem....its an 85 dodge ram d-150
Old Feb 5, 2009 | 06:56 PM
83dodgeswb4x4's Avatar
83dodgeswb4x4
I have indeed had the same trouble. Try tapping the bottom of the washer motor and see if they start working. After I half beat mine to death over the period of about two years I had to wash the motor off so I pressure washed the entire engine compartment and since then they have worked like a dream. You could also disconect the wires at the motor and check with a volt meter and make sure the juice is getting there. If not I would check the switch to make sure it is getting power.
Old Feb 6, 2009 | 12:19 AM
bubba232009
Default thanks
hey thanks worked like a charm....went out at midnight beat the crap out of the motor and they came right on.....i'll remember that for next time
Old Feb 9, 2009 | 02:28 PM
charlie1935's Avatar
charlie1935
I've had that happen on my 87 D100 and 5th ave. Just run a ground wire from the wiper motor to the firewall. These motors have an internal ground that goes to one of the mounting bolts and they lose it sometimes.
