poor idle
Old Mar 8, 2009 | 06:35 AM
mohadib's Avatar
mohadib
howdy!
So i replaced the carb mounting gasket. replaced all my smaller vaum lines. Found my egr vacum pump was wired backwards, fixed that. Fixed and exhaust leak. NOw the truck idles real nice. Still misses a little buit ever so slightly. Maybe I should time it? Or change cap/coil/wires? Already put new plugs in. What do you guys think I should do next?
Thanks,
dib
Old Mar 8, 2009 | 06:38 AM
mohadib's Avatar
mohadib
I scored an engine hoist and motor stand too, $150. What do you think? You can see them in the photo of meh hawt dodge!
http://papernapkin.org/pastebin/reso...geEntryId/4845
Seem like a decent deal?
Thanks,
dib
Old Mar 8, 2009 | 08:03 AM
Mad Mudder's Avatar
Mad Mudder
Originally Posted by mohadib
howdy!
Thanks,
dib
Go a head and changes those cap/coil/wires. I put a accel ing. system in mine and it runs better.
Old Mar 8, 2009 | 08:53 AM
SEAL's Avatar
SEAL
What is an EGR vacuum pump? If you wire it backerds does it make pressure instead of vacuum?
Old Mar 8, 2009 | 04:21 PM
nemesis_SS's Avatar
nemesis_SS
the EGR (Engine Gunk Remover) is just a vacuum to clean out the engine bay. So like if you get leaves and oil and stuff in the motor compartment they can be sucked into the carb or the pulleys, which is what was happening to mohadib here. It was on blow instead of suck. All he had to do was switch it the EGR to vacuum and he sucked all that gunk up
Old Mar 8, 2009 | 04:35 PM
mohadib's Avatar
mohadib
lol nemisis
Old Mar 9, 2009 | 03:10 AM
mohadib's Avatar
mohadib
When i get a little $$ (soon) I'll replace coil/wires/cap. I'll let you guys know how it goes. I really want this engine to run well. Before I go any further should I compression test it? To make sure I'm not polishing a terd? I'm pretty new to autowork if you havent noticed
Thanks,
dib
Old Mar 9, 2009 | 03:15 AM
mohadib's Avatar
mohadib
TBH... http://papernapkin.org/pastebin/reso...geEntryId/4858
Thats where the coil/wire/cap moneys went Man im sore \o/
dib
Old Mar 9, 2009 | 09:20 PM
lugnuts's Avatar
lugnuts
I've owned enough junk to know you can't polish a turd, but you can dern sure paint one lol. A comp. test ain't a bad idea. All cyls should be within 15 psi of each other, a little wider variation means you have some wear.
Old Mar 10, 2009 | 02:32 AM
mohadib's Avatar
mohadib
Thanks for all the help so far Nemisis , Lugnuts, everyone else. I'll keep you guys updated. Got a compression tester now.
Lugnuts..hmm, damed science, just when you think you got stuff sorted... http://www.youtube.com/watch?v=hBj6PonX14A
Cheers
dib
