91 w-150
Old Mar 19, 2009 | 03:57 PM
SEAL's Avatar
SEAL
The idle speed control can give the stalling after warm up. Will it idle in gear when warm if you give it gas to keep idle up? If it will adjust idle up to spec with ISC disconnected until you can replace it. Or do like lugnuts if you can handle the cold run problems.
Old Mar 25, 2009 | 08:31 PM
brucris's Avatar
brucris
I have replaced the isc in the past but it may not work. I will have to see if it is receiving the proper signal voltage.
