cam/ lumpy idle 318
Old Mar 26, 2009 | 10:22 PM
NAR-D150's Avatar
NAR-D150
Default cam/ lumpy idle 318
i love the lumpy idle sound, my truck sounds really nice when i first start it after a day of sitting (flowmaster 40, no cat), i was wondering if that is a carb adjustment, i have also heard that it is due to a different camshaft? if i was going to get a different camshaft would i have to change anything else besides the timing? thanks also what cam duration and cam company to buy from and stay away from
Old Mar 26, 2009 | 10:34 PM
NAR-D150's Avatar
NAR-D150
forgot to also ask how easy for me to put cam in, or how much would it generally cost to have one put in? thanks
Old Mar 27, 2009 | 09:40 PM
83dodgeswb4x4's Avatar
83dodgeswb4x4
Carb adjustment really has little to do with loping engines. This can be effected slightly by adjusting the timing, but its mostly the cam that gives the lope. I've had good luck with both Edlebrock and Crane cams. Most of the name brands I would be willing to use. As for componets, with an engine thats worn, its suggested replacing liftes, which is no big deal as they normally come with the cam. Installing one involves pulling the radiator, the water pump and the timing cover. If you check out the web sites for most cam manufactures, they should have a chart indicating if the cam lopes or has a smooth idle. It really depends on if you want low end torque or high end as to lift and duration. normally long duration, and high lift lends itself towards torque. where as shorter duration and less lift is more for speed. Or at least thats what I have always been told.
