oil pressure
Old Jul 24, 2009 | 06:18 PM
nemesis_SS's Avatar
nemesis_SS
Default oil pressure
hey guys, where is do your oil pressure needles sit? mine sits just barely above the L, is that normal?
1991 318, TBI, 2wd
ive heard the factory gauges can be unreliable, is there anywhere i can T in a secondary?
Old Jul 24, 2009 | 06:37 PM
kev2's Avatar
kev2
dash gauges are very very inacurate.
Suggest you temp install a mechinical gauge to get a true reading.....knowing the oil pressure will guide the next step.
V8 engines that era will have low oil pressure...
Old Jul 24, 2009 | 06:57 PM
charlie1935's Avatar
charlie1935
Even an aftermarket electric gauge is much better than the factory one.
Old Jul 25, 2009 | 10:26 AM
nemesis_SS's Avatar
nemesis_SS
ok. i never worried about the low reading, but the trucks been having some issues which i cannot figure out and my dad said "well if the oil gauge is reading low, start there."
Old Jul 25, 2009 | 09:39 PM
Mad Mudder's Avatar
Mad Mudder
1991 318, TBI, 2wd
Mine dose the same thing.
Old Jul 25, 2009 | 11:06 PM
moparborn's Avatar
moparborn
Same here,it is normal to have about 6 pounds at idle.
Old Jul 26, 2009 | 12:36 AM
charlie1935
I know the factory says six lbs. is ok at idle but I have never had any vehicle have that little except my 1934 Chevy that did not have a full pressure oiling system.
All the mopars I've had idled around 25 to 30 lbs.
Old Jul 26, 2009 | 11:08 AM
nemesis_SS's Avatar
nemesis_SS
25-30 at idle? my haynes says 8lbs is ideal, but i figure with age 6lbs is acceptable.
how do i get an accurate reason on the oil pressure? im gonna drop the pan today and check for a sludge blocked pickup screen. i just feel stupid doing all that work when i dont really even know if my prussre is low
Old Jul 26, 2009 | 11:28 AM
charlie1935
The best way is to hook up a mechanical gauge and see what it reads. Some of the chain parts stores may have a loaner you can use without buying one.
