1990 Ramcharger crankshaft sensor
Old Aug 5, 2009 | 07:34 AM
drelectrix's Avatar
drelectrix
Default 1990 Ramcharger crankshaft sensor
I posted this in the Ramcharger section for three days with no response. I am hoping someone can help me with the following. Thank you in advance.
Can someone tell me the location of the crankshaft position sensor. I can't seem to locate it. The way I understand it is located on the back of the motor (passenger side)? can you maybe get me a little closer than that cause I couldn't find it. The reason I am trying to replace this is because I am not getting spark at the spark plug, however I am getting power and ground to the coil while the key is in the (ON/Run) position. I also seem to be getting ground at the coil with the key both (ON) AND (OFF). They way I understood it is that the ground to the coil is supplied providing there is signal from the crank sensor to the computer which controls the ASR. Am I replacing the correct part? Crankshaft sensor location please!!!
Now that I have fumbled my way through this disclosure, thanks for your help in advance.
d-
Old Aug 5, 2009 | 12:48 PM
crazzywolfie's Avatar
crazzywolfie
it is in your distributor.
