lic plate and back up lights,inspection in NC
Old Oct 13, 2009 | 01:46 PM
tooltime's Avatar
tooltime
Default lic plate and back up lights,inspection in NC
these lights on truck dont work.it did have the lic plate work(1) and i changed bulbs and now nothing.does anyone know if NC they have to work?What can i do to fix?how hard is it to run a wire(s) for a new lic plate light and to where? a wire to lights and to the switch,ground and power(batt)?thanks
Old Oct 13, 2009 | 03:25 PM
crazzywolfie's Avatar
crazzywolfie
did you check your fuses? mabe there is a bad connection in the soccet. i had problems getting my lic plate light working when i replaced the bulbs. i had to break the old light bulbs to get them out. i think you can get a ticket if they don't work but you will more than likely only get a warning. it is such a small thing that most cops wont even bother or notice.
Old Oct 13, 2009 | 03:49 PM
tooltime's Avatar
tooltime
on the lic plate light 1 worked.i messed with it 1 time and could not get them out so i stopped,until the other day.now both sides dont work and yes the 1 i had to bend the brass part to get out,socket is fine.the book calls for 2 kinds of bulbs and have used both.they seem loose though.i need to get it fix so i can get a inspection.yes the fuse works if i remember it has other things on it also(fuse).
Old Oct 13, 2009 | 04:19 PM
SEAL's Avatar
SEAL
There is a spring inside the socket that can rust and brake and then the contact is not pushed out against the bulb contact. Push the wire from behind toward the bulb and get that spring free. If the spring is broken replacement sockets are available and cheap. If the inside of the socket is badly rusted the bulb will not ground to the socket properly. Make sure the socket itself is grounded to the bumper and that you have a good ground from the bumper to the frame.
Old Oct 13, 2009 | 07:37 PM
crazzywolfie
Originally Posted by tooltime
on the lic plate light 1 worked.i messed with it 1 time and could not get them out so i stopped,until the other day.now both sides dont work and yes the 1 i had to bend the brass part to get out,socket is fine.the book calls for 2 kinds of bulbs and have used both.they seem loose though..
if the light bulbs in the lic plate sockets are loose it might prevent them from making a good connection. you could use some plyers and scwish the the socket a bit till the light bulb fits snug. you should also test the sockets for power with a multimeter.
Old Oct 13, 2009 | 11:54 PM
Mad Mudder's Avatar
Mad Mudder
Yes you need them here in NC.
Old Oct 27, 2009 | 06:58 AM
RSDodgelover's Avatar
RSDodgelover
Most states require all lights that are on the vehicle to work as well as having a minimum so you can probably get by with one lic light if you remove the other. I have found that a bad ground or rust is often the fault when working on older lights and it is often easier just replace the lic plate lights if there isn't something obvious. If you try to clean and squeeze the socket or stretch the spring you have a good chance of having an intermittent light which will catch the eye of law officers.
