90 runnin rich
Old Feb 10, 2010 | 01:13 AM
schulteff's Avatar
schulteff
Default 90 runnin rich
i just bought a 90 dodge half ton. it has a 318 and its runnin rich. how can i fix this. it has the tbi, i noticed that it has a couple wire clusters runnin into it, would theyre be a controller somewhere? or is it just a O2 sensor problem? any help is greatly appreciated, thank you!
Old Feb 10, 2010 | 02:34 AM
crazzywolfie's Avatar
crazzywolfie
could be an o2 problem. you might want to try unpluging the o2 sensor and reseting the computer. with the o2 sensor being unplugged it should use the default fuel to air ratio.
Old Feb 10, 2010 | 02:59 PM
schulteff's Avatar
schulteff
How do I reset the computer? Just disconnect the battery??
Old Feb 10, 2010 | 05:59 PM
crazzywolfie
ya just disconnect the battery and try turning on the lights , then reconnect the battery.
Old Feb 10, 2010 | 10:04 PM
schulteff's Avatar
schulteff
okay thank you!! i'll give it a try and see if it works. my mait. req. light has been on too, maybe it'll take care of that!!
Old Feb 12, 2010 | 08:09 PM
schulteff's Avatar
schulteff
well that turned the check engine light on and thats about it. still runnin rich. i'm lost!
Old Feb 13, 2010 | 07:25 AM
SEAL's Avatar
SEAL
If you have a check engine light pull the codes.
Old Feb 14, 2010 | 03:40 AM
schulteff's Avatar
schulteff
the check engine light went off when i plugged the O2 sensor back in. it does have a "maitnance required" light on though. what could be throwing that?
Old Feb 14, 2010 | 05:16 AM
SEAL's Avatar
SEAL
The maintenance required light comes on after a certain number of miles. You can pull the bulb or wait for it to burn out or go to the dealer and pay $75.00 to have them turn it off with a special tool. I removed the bulb. This light does not have anything to do with any problem with the truck and is only a mileage reminder. If you choose the dealer this light will come on again in a certain number of miles so it is a never ending drain on your wallet.
Old Feb 14, 2010 | 04:07 PM
schulteff's Avatar
schulteff
pull the bulb it is!! thank you!
