Edelbrock 440 "Power Package"
Old Jul 17, 2010 | 11:57 AM
aaron7's Avatar
aaron7
Default Edelbrock 440 "Power Package"
Looking at this:
http://www.edelbrock.com/automotive_...chrysler.shtml
http://www.summitracing.com/parts/EDL-2087/
For my 440 in the truck. It's idle to 5500rpm which is perfect for a truck.
I can't seem to find dyno tests with this kit nor do I know what carb would be best for it.
Anyone know? Anyone running this kit?
Old Jul 17, 2010 | 12:21 PM
charlie1935's Avatar
charlie1935
It says on their site a 750 to 800 CFM carb.
Old Jul 17, 2010 | 02:21 PM
crazzywolfie's Avatar
crazzywolfie
that engine came out of an RV and as is it should have a fair bit of power, torque and will not be too hard on gas. i don't think the power gain would be worth $2200. if you are going to start spending that type of money you would be better off to buy turbo kit or super charger.
Old Jul 17, 2010 | 05:40 PM
aaron7's Avatar
aaron7
Well this motor is rated 230hp/360lb-ft which is sad... and the gas mileage isn't a concern really.
Have a suggestion for a matching 750-800CFM Edelbrock carb?
Old Jul 17, 2010 | 07:17 PM
crazzywolfie
dodge engines tend to be under rated. the only way to find out would be to tune it up and have it tested on a dyno.
Old Jul 23, 2010 | 05:37 PM
89ram150's Avatar
89ram150
While it'll give you more than enough torque, it's probably alot lower compression than say a muscle-car era 440. My dad has an edelbrock top end on his '70 383 with 10:1 pistons and a purple shaft-style cam that's putting out just over 420 hp and around 400 torque. But for a truck application, torque is where it's at, so even a lower compression big block should be a handful to drive, especially with a light-rear ended truck.
