newbe needs help
Old Aug 18, 2010 | 06:26 PM
snobuster's Avatar
snobuster
I will check out the EGR and see if that is the problem. Thanks for that input.
Old Sep 15, 2010 | 08:06 PM
snobuster's Avatar
snobuster
I finally got a chance to work on this truck again. I checked the egr by running the engine and increasing the rpm fromm idle to 2000. The shaft in the egr moved up as it is supposed to, I plan to do the vacuum test to see if it causes a stall as the book says it should, it could be plugged up in the passages. I will post what i find as soon as I get it checked. Thanks for the info.
