need help decoding a VIN
Old Aug 17, 2010 | 10:16 PM
amc75matador's Avatar
amc75matador
Default need help decoding a VIN
I've got a haynes manual and a chilton's manual, I can't figure out what I have, I just got this a little while ago and it needs an intermediate axle on the driver's side
Anyway, help in decoding this VIN would be appreciated
1B7JW24W3HS371960
1987 dodge pick up 4x4 auto 3/4ton is all I know
thank you
also looking for a good tailgate
Old Aug 18, 2010 | 01:31 AM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF!
This is what I know about VIN decoding, albeit its mostly for 1994+ newer trucks.
1 = Built in USA
B = Dodge
7 = Truck
J = 7000 to 8000 lbs GVW
W = ? something no longer used in 1994+ VINs.
2 = 2500 series
4 = Extended cab or wagon/van
W = This states what engine you have, and changed year to year sometimes. For 1994+, W means the truck has a V10. I doubt you have that.
3 = Chrysler's "Check Digit", no meaning
H = How sure are you that its a 1987? According to H here, its a 1984 model.
S = Built at Dodge City (Warren, Michigan)
And the last six are your truck's unique serial number.
Let me move this over to 1st gen Ram, see if they can get you any more ideas.
Old Aug 18, 2010 | 05:37 AM
SEAL's Avatar
SEAL
Head for the local dealer. They can decode the VIN and give you a build sheet that will identify all of the major components that came stock in your truck.
Old Aug 19, 2010 | 04:42 PM
lilred7879's Avatar
lilred7879
Any time you need to do this just go here - http://ramchargercentral.com/index.php?action=vindecode
You entered the VIN Number: 1B7JW24W3HS371960
1Country of OriginUSABMakeDodge7Type of VehicleTruckJGVWR7001-8000#WTruck Line4wd2Series250 or 2500 for 94 & later4BodyConventional CabWEngine360/5.9 4BBL (Federal) or 225/3.7 2BBL for 82 or 8.0L 10 Cyl. MPI for 94 & later3VIN VerificationHModel Year87SAssembly PlantWarren Main Plant or Dodge City for 88 & later371960Sequential Serial Number
Old Aug 21, 2010 | 08:12 PM
amc75matador
thank you, and thanks for the useful link as well
