Need 440 oil pan for 2wd!!
Old Sep 1, 2010 | 11:08 AM
aaron7's Avatar
aaron7
Default Need 440 oil pan for 2wd!!
Having a hell of a time trying to find an oil pan for my 84 D250 440 swap.
It needs to be a 2wd; 4wd is front sump and won't work.
Any ideas?
Old Sep 1, 2010 | 05:38 PM
89ram150's Avatar
89ram150
What about from an older full size passenger car?
Old Sep 1, 2010 | 07:02 PM
aaron7's Avatar
aaron7
I'm not sure if the 2wd truck and the car used the same crossmember location?
I just found a site that carries the right pan but they are $100! Wish I could find one in the boneyard :/
Old Sep 2, 2010 | 11:03 AM
RSDodgelover's Avatar
RSDodgelover
I don't think the car pan will work, I put a 400 BB from a car into a 2wd truck and the truck needed a rear sump but the car had a middle sump. I actually had to splice the top of one oil pan (that fits the motor) to one that had the sump in the right location. It was a real pain but I was on a budget and parts weren't as available then (1986 or 87) as they are now. Also I had not even seen the internet at that time. Good luck, mine was a fun toy and very dependable.
Old Sep 2, 2010 | 11:27 AM
aaron7's Avatar
aaron7
So if the 2wd and 4wd trucks were rear sump, and cars were mid sump... wth is my front sump pan from (besides Winnebagos)??
Old Sep 3, 2010 | 10:01 AM
RSDodgelover
I might be remembering wrong (It was 20+years ago) so the front sump might be for the 2wd. Sorry for any confusion, I just remember that I ended up making an oil pan for it because I could not find one that worked.
Old Sep 3, 2010 | 10:07 AM
aaron7's Avatar
aaron7
But I have a 2wd (84 D250) and it's a rear pan setup. I was told the 4wd was the front sump?
Old Sep 3, 2010 | 11:11 AM
RSDodgelover
Cool
I think that might be right. I do remember that the 4wd and 2wd were different. At that time I found several 4wd pans but no 2wd. Good luck. Have you found the big block motor mounts and the exhaust manifolds?
Old Sep 3, 2010 | 11:38 AM
aaron7's Avatar
aaron7
I'm using the mounts from the RV; they bolted right in and everything lines up.
I went with some nice full length headers for the exhaust. I'll be running true duals down the outsides of the frame.
Old Sep 5, 2010 | 01:12 PM
ol'shaky's Avatar
ol'shaky
Usually the 4wd are a rear sump. With a front sump in a 4wd, the sump will be positioned directly over the front axle tube - one good bounce and there goes your pan/pickup tube.
