93 W150 help!
Old Sep 29, 2010 | 10:37 PM
saints_fan77's Avatar
saints_fan77
alright thanks
Old Sep 30, 2010 | 11:35 PM
saints_fan77
Alright next time i am out by a dealership i will get a build sheet and ill figure out my tranny situation. Another problem i am having is it is idling very high? any ideas on that?
Old Oct 1, 2010 | 05:38 AM
SEAL's Avatar
SEAL
You really have no control over the idle as it is controlled by the computer.
Old Oct 2, 2010 | 02:13 AM
steve63's Avatar
steve63
on youre high idle situation,check and see if you have any trouble codes to rule those out.
Old Oct 2, 2010 | 01:00 PM
pickerbush18's Avatar
pickerbush18
Overdrive unit is a separate add on to the 3 speed 727. You probably have 46Rh trans. The overdrive unit will kick in only when the computer sees a certain speed attained. If your speedometer doesn't work neither will overdrive.
