no left turn signal when marker lights on.
Old Nov 11, 2010 | 04:48 PM
crazzywolfie's Avatar
crazzywolfie
Default no left turn signal when marker lights on.
every time i turn my marker lights on the left turn signal light on the dash come on and when i try to use the left turn signal they will not work but the right ones will. when i turn the hazard lights on while the marker lights are on all except for the rear left marker light flash. the rear left light just stays on. when the marker lights are off everything works fine.
Old Nov 11, 2010 | 05:14 PM
SEAL's Avatar
SEAL
Sounds like the rear left wires/contacts/bulb are crossed or shorted together.
Old Nov 11, 2010 | 07:16 PM
crazzywolfie
that is what it seems like but they had all work before i fixed the bad ground wire on the marker light. the wires going to the marker light look stock and that no one has replaced the light socket. the only thing i have done was install a socket for the back-up light and replace the front 2 marker light sockets.
Old Nov 11, 2010 | 08:05 PM
crazzywolfie
SEAL, i think you were right. i think i had mixed up a few wire on the front left marker light that caused a problem with the rear left marker light. now the only problem i have is the rear left turn signal and brake light does not work and i tried replacing the bulb and it still does not work. i think i will have to take a look at tomorrow when i can actually see out. hopefully the carb swap will go smoother than this.
Old Nov 12, 2010 | 12:44 PM
SEAL's Avatar
SEAL
Light socket problems especially on the rear are quite common on our trucks. The spring that sits under the contact plate in the socket can corrode and freeze or even break. This does not allow proper pressure to give a good contact with the bulb.
Old Nov 16, 2010 | 08:49 PM
crazzywolfie
the problem with the light was a bad connection at the one of the plugs in the frame.
