92 Dodge W150 Transmission Swap?
Old Nov 14, 2010 | 02:14 AM
mud_bogger_89's Avatar
mud_bogger_89
Default 92 Dodge W150 Transmission Swap?
i have a 92 dodge W150 4x4 automatic w/ overdrive. im wanting to know if a 90 model transmission would work in my 92? Can anyone please help
Old Nov 14, 2010 | 06:14 AM
Ironmower's Avatar
Ironmower
should fit
Old Nov 14, 2010 | 03:02 PM
pickerbush18's Avatar
pickerbush18
Default trans swap
Should fit but in later 92 (I think March) the 318 V8 and 6 cylinder changed to multi-port fuel injection from throttle body. The new Magnum engine was offered with 46rh heavy duty trans. The 90 model has light duty 42rh trans. Wikipedia has the story of the Dodge trucks if you want to look it up.
Old Nov 14, 2010 | 09:01 PM
mud_bogger_89
i hope it fits. i just bought a transmission and plan on puttin it in this weekend
Old Nov 15, 2010 | 07:28 AM
pickerbush18
I did a swap from a 92 Ramcharger to my 92 W250 which was OK but what I found was that the Ramcharger torque convertor had a slightly different hole pattern and it was a lock up convertor and my original was not. The odd hole was .060 off which I just enlarged the hole a little to be able to get the screw in. Good luck.
Old Nov 15, 2010 | 10:32 PM
Gerehead8's Avatar
Gerehead8
What motors were in those trucks?
Old Nov 16, 2010 | 01:54 AM
mud_bogger_89
Both are 318 throttle body
Old Nov 16, 2010 | 06:55 AM
Ironmower's Avatar
Ironmower
Those will only fit one-way. You can get three in, but not the fourth.
Old Nov 17, 2010 | 04:13 AM
mud_bogger_89
If the 90 model transmission dont work right in my 92.. What will it do when i try to drive it?
Old Nov 17, 2010 | 07:36 AM
SEAL's Avatar
SEAL
It is hard to believe that this thread has gone on this long without the actual identification of both transmissions that are being compared. No one can be certain that either of these transmissions are original equipment in either of these trucks without actual identification of the transmissions in question unless you have owned the vehicles from the showroom floor. Copy down the identification numbers of each transmission and drop by your local dealers parts department and find out the facts. You are talking about an awful lot of work to be assuming anything. JMHO
