Oil pressure
Old Dec 17, 2010 | 03:07 PM
pickfiddle's Avatar
pickfiddle
Default Oil pressure
So my oil pressure gauge hasn't worked since I've had the truck. It's an 89 d100. The sending unit doesn't appear to be leaking, is there a way to test it on/off the engine?
Old Dec 18, 2010 | 06:22 PM
charlie1935's Avatar
charlie1935
They can be bad and not leak.
Old Dec 18, 2010 | 06:31 PM
pickfiddle's Avatar
pickfiddle
Is there a way to check so I don't go out and buy a new one if it's just a bad gauge??
Old Dec 18, 2010 | 06:36 PM
crazzywolfie's Avatar
crazzywolfie
i don't know 100% how they work but i am pretty sure they work using resistance just like most of the other gauges.
Old Dec 19, 2010 | 07:15 AM
Ironmower's Avatar
Ironmower
I don't have much faith in the stock electric type. I'd reccomend going to an after market manual type.
Old Dec 19, 2010 | 12:59 PM
Gerehead8's Avatar
Gerehead8
Just go buy a sending unit from autozone as they allow you to return it even if you have used it slightly. This is how I do a lot of my diagnosing.
Old Dec 23, 2010 | 09:44 PM
rocketvette95's Avatar
rocketvette95
I know on my truck the oil needle is about two lines from the H.So I think that is great oil pressure
Old Dec 23, 2010 | 11:18 PM
pickfiddle's Avatar
pickfiddle
I'm just gonna put a second press. Gauge in and pull the old sending unit
