Dim marker light
Dim marker light
1990 W150 when the driving lights are on, the right front side marker light is dim and the right turn indicator is on solid in the dash. When I turn the right turn signal on the right side blinker outside and in the dash blink normally. I guessing it's a bad ground somewhere but I can not find it. Am on the right track or should I look at something else.
you could try running a piece of wire from the negative terminal on the battery to the ground on the light. if this does not help i would checking the ground on the other lights. could also be that someone replaced one of the marker light sockets and re wired it wrong. i know i did and had the exact same problem.
