not running
Old Jan 22, 2011 | 07:52 PM
ROADRUNNER33's Avatar
ROADRUNNER33
Default not running
I just put headers on my truck. When I drove it it died on me but it started up after I waited a while.I got in it to move it the next day and it did the same thing but this time it didn't crank back up. I'm running the headers open and I have not reinstaled the o2 sensor. Is this the problem?
Old Jan 22, 2011 | 11:59 PM
wontacceptthis's Avatar
wontacceptthis
Nah. No 02 sensor just makes it run waaaaaaaaaay rich. What headers did you get? Just wondering.
Old Jan 23, 2011 | 10:20 AM
ROADRUNNER33
Hooker
Old Jan 23, 2011 | 11:23 AM
SEAL's Avatar
SEAL
I agree that the O2 sensor is not causing this problem. If you would like more help we need more info (year, model, engine size and tranny). If you put these things in your header to the right under Vehicle we will always know this info when you post.
Old Jan 23, 2011 | 03:21 PM
ROADRUNNER33
It's a 89 w250 with a 360 and torqueflite
Old Jan 23, 2011 | 08:43 PM
ROADRUNNER33
Could it be the Injectors
Old Jan 23, 2011 | 08:47 PM
wontacceptthis
Sure. Could be anything at this point? Are you getting any spray from the injectors? Any spark?
Old Jan 24, 2011 | 07:40 AM
SEAL's Avatar
SEAL
You need to start eliminating systems. Take the air cleaner off and look down inside the throttle body. You should see a cone of fuel spray at the base of each injector. The cone should be solid with no gaps or streams and should reach the sides of the throttle body throat. This may require a flash light and is easier to see when out of direct sunlight. Have you tried to pull the computer codes?
