87 dodge ram dies when wheel is turned
Old Feb 17, 2011 | 01:55 PM
shadowdragon's Avatar
shadowdragon
Default 87 dodge ram dies when wheel is turned
hi all i just got an 87 dodge ram and we did a tune up on her runs fine sounds great but she still has a tendency to bog down or die if i turn the steering wheel all the way right or left, also she started dieing after her first long trip around 200 miles to get here home i got off the interstate and at the bottem of the ramp she died, fired right back up but then had a hard time getting going again, and then died 2 more times once at a stop light and once while making a left turn both times had trouble getting going again but did get going. we then took about an hour break and headed out the final 30 miles and she did just fine on that run didnt die or have any problems tho i didnt try and make any sharp turns either so. but she still bogs down or dies if i turn the wheel fully left or right, so what causes this behavior ? thank you all for your help
Old Feb 17, 2011 | 03:41 PM
SEAL's Avatar
SEAL
Does it squeal when it does this? Try adjusting the power steering unit so that there is slack in the belt and then turn the wheel hard left/right and see if it quits.
Old Feb 17, 2011 | 03:49 PM
crazzywolfie's Avatar
crazzywolfie
to me it sounds like the carb is not correctly set or the timing could be off.
Old Feb 17, 2011 | 04:23 PM
shadowdragon
sorry to sound dumb here but how are the carb and timing connected to the steering ? and yes i think theres a squeel i'll run up and check it out. thanks for the quick response, also could a low idle have anything to do with this either? i just wonder because she dies on long trips when i stop, she gets going again but has a hard time, almost feels like a clogged catalytic converter. not to sure thanks again
Old Feb 17, 2011 | 05:51 PM
crazzywolfie
if your timing is not set right it can cause your truck to stall easier. if your carb is running a bit rich it could stall when put under a bit of stress.
Old Feb 17, 2011 | 11:25 PM
shadowdragon
ahh now i see thank you for the explanation. does that year have a computer hook up to get codes from? and if so where is it and what kind of connection is it ? thanks
Old Feb 17, 2011 | 11:52 PM
crazzywolfie
if your truck has a computer it will be located on the drivers side fender behind the battery.
you should be able to retrieve any code using this process if it has a computer.
Originally Posted by SEAL
ON-BOARD DIAGNOSTICS Dodge OBD1 Pre 96
1. Cycle the ignition key ON-OFF-ON-OFF-ON within 5 seconds. To cycle the ignition key ON means to turn it only as far as it takes to get the radio to come on. It does not mean to turn the engine on.
2. Count the number of times the "check engine" lamp on the instrument panel flashes on and off. The number of flashes represents the code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses separate individual codes. For example, flash-flash-flash [pause] flash-flash represents the code 32.
A code of "55" represents end of error codes. If this is all you get then no error codes are stored in the computer. This is the normal condition
CODE Description of Trouble Code
11 Timing belt skipped 1 tooth or more from initial learned value, Intermittent loss of either camshaft or crankshaft position sensor, No crank reference signal detected during engine cranking
12 Direct battery input to PCM was disconnected within the last 50 key-on cycles (normal)
13 No change in MAP from start to run
14 MAP sensor voltage too low
15 No vehicle speed sensor signal
17 Closed loop temp not reached or engine cold too long
21 02s sensor problem (oxygen sensor), upstream or down stream
22 Engine coolant temp sensor out of range
23 Intake air temp sensor out of range
24 Throttle Position sensor out of range
25 Idle air control motor circuits, target idle not reached (+/- 200),vacuum leak found
27 Injector control circuit
31 Evap purge flow monitor failure or evap solenoid circuit
32 EGR system failure
33 A/C clutch relay circuit
34 Speed control Solenoid circuits
35 Rad Fan control relay circuit
37 Torque converter clutch solenoid CKT or park/neutral switch failure
41 Generator field not switching properly
42 Fuel pump relay control ckt, Auto shutdown relay control ckt, No ASD relay output voltage at PCM, Fuel level sending unit volts out of range, Fuel level unit No change over miles
43 Multiple/ single cylinder misfire
44 Battery temp sensor volts out of range
45 Overdrive solenoid shorted or open (automatic transmission only)
46 Charging system voltage too high
47 Charging system voltage too low
51 Fuel system lean
52 Fuel system rich
53 Internal control failure
54 No Cam signal at PCM
55 End of error messages (If you get this only, no errors were found)
62 PCM failure SRI mile not stored
63 PCM Failure EEPROM write denied
64 Catalytic Converter Efficiency Failure
65 Power steering switch failure
Old Feb 20, 2011 | 05:13 PM
slicedtomatoes's Avatar
slicedtomatoes
you could also possibly...remove the power steering belt...im thinking you have a Vbelt setup then you would know if steering is the issue....im betting its an engine prob though..... egr valve sticking carb problems...check the plugs wires all to often overlooked??
