Help with making my truck horning
Old Mar 8, 2011 | 11:16 AM
crazzywolfie's Avatar
crazzywolfie
no. there is a bolt on them that you should be able to see from the grille. you would just turn them in or out till it works better
Old Mar 9, 2011 | 07:47 AM
SEAL's Avatar
SEAL
A simple bad ground can cause this. There is only the power wire that makes the horn work, as you can see, so a ground is required to complete the circuit.
Old Mar 12, 2011 | 06:24 PM
RamKing's Avatar
RamKing
i got it working. it was a bad connection from wire to horn, still working now i cleaned the connections and put grease on it hopefully that hold for now, thanks for all the help with troubleshooting
