will these tires fit?
Old Mar 21, 2011 | 01:40 PM
skote888's Avatar
skote888
Default will these tires fit?
I want to know if I can fit 31x10.5R15 tires on my 81 power ram without a lift.
Stock size is 235/75/R15
Thanks
Heres a link to the site with the tires
http://www.canadiantire.ca/AST/browse/4/Auto/1/Tires/LightTruckTires/PRD~0052335P/Goodyear%252BWrangler%252BTerritory.jsp?locale=en
Old Mar 21, 2011 | 01:56 PM
crazzywolfie's Avatar
crazzywolfie
they should fit. there is only be about a 2inch difference in diameter between the stock tires and the ones you are looking at.
Old Mar 21, 2011 | 02:27 PM
skote888's Avatar
skote888
how about width, should i be ok or would i need spacers? I dont want to rub.
Thanks
Old Mar 21, 2011 | 02:56 PM
crazzywolfie
there should only be about a 0.75 inch difference in width. i don't think you should need spacers. it not like your trying to run 33's.
Old Mar 21, 2011 | 04:52 PM
skote888's Avatar
skote888
thanks i appreciate the help
Old Mar 21, 2011 | 08:30 PM
slicedtomatoes's Avatar
slicedtomatoes
i had 31-10.50/15 on my 78 4x4 with no rubbing
Old Mar 21, 2011 | 10:43 PM
nyteterror's Avatar
nyteterror
mine came with 31/10.50/15 from the factory. at least the tag inside the door jam says
Old Mar 22, 2011 | 03:14 AM
jewalker7842's Avatar
jewalker7842
It should fit fine. I put 265/75/16 on mine from the stock 235/75/15 and have no clearance problems.
Old Mar 24, 2011 | 03:41 AM
Husker350's Avatar
Husker350
Yeah, you shouldn't have a problem! I put 285x75x16's on my 93 W350 which are basically 33's.. being as its a W350 i'm probably sitting a little taller stock. But you still shouldnt have a problem
Old Mar 24, 2011 | 11:59 AM
aaron7's Avatar
aaron7
I've got 31x10.5x16.5 on my D100 with a D250 body. Even with the heavier 440 it fits fine though if I'm turning and hit a bump it rubs for a second.
