1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Truck been sitting up for a while. Not getting fuel. Checked voltatge to fuel pump and voltmeter shows 2.5 volts. Would that be right? Just wanted to make sure before I dropped the tank (lazy). Thanks
Voltage should be 12 volts. Before you drop the tank you might want to find out why you don't have the required 12 volts. I would start at the ASD relay and go from there. The ASD is about in the middle of the circuit and will tell you what to check next.
