1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
you don't have to let it cure for a couple of days if you mix the bondo right. it only took about 5 hours per side on my short box to clean, bondo, sand, prime and clear coat but them again my dad has been doing body work for years.
Well I let my brother mix it so he probably got it a little off. The only spot we really need to fix is where we filled in the hole for the gas cap.
I did mine, hell it was 80% of the way there because of the clear coat peel...pix coming soon. Also did the grille in textured flat black plastic paint. now THAT looks killer!
