1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I don't see an idle stop solenoid relay in the diagram. I see a stop solenoid relay(ASD). The ASD relay is on the drivers fender just below the hood spring.
Another question -- The vacuum solenoid on passenger fender well works if you appy 12v and ground --but the 2 wires going to it (orange)
(white with red tracer) both have 12v + how does it pick up a ground to open? Or is there a shorted wire or diode in circuit?
Thanks
