92 engine question
Old Jun 1, 2011 | 08:33 PM
92w150ram's Avatar
92w150ram
Default 92 engine question
i have a 92 with a 4 speed manual. its 4 wheel drive. im looking to swap for a diff motor because mine is shot. im wondering if anyone knows what year of motors will mate up with the transmission. can i just get an old 70s 318, 360, 400, 440?. my plan for those would be to use a carb. or can i get like motor from like a 97 jeep with a 5.9 with wiring harness and cpu? just trying to see what my cheapest route would be.
Old Jun 2, 2011 | 05:00 PM
viperredram's Avatar
viperredram
the bellhousing on big blocks are different you will hav to get bellhousing with motor to match your tranny . also where is your crank sensor? on my aotomatic 318 1992 there is ahole in bellhousin for the sensor. could create problem with different motor
Old Jun 2, 2011 | 05:25 PM
crazzywolfie's Avatar
crazzywolfie
if you get a newer motor all the current wiring should be the same but if you switch to carb you would replace the ignition system but you could still use a newer magnum engine if you wanted. just have to switch intakes, add a fuel pressure regulator and switch ignition system and you would be good to go. i think the big thing is to find a engine that was from a truck with a standard transmission because if it is not you may have to have the crank machined.
Old Jun 4, 2011 | 01:36 PM
92w150ram's Avatar
92w150ram
is the crank a diff size in other vehicles?
found a 90 360 that runs good. intake, dizzy, ignition, carb. should that do it?
Old Jun 4, 2011 | 05:18 PM
crazzywolfie
no the crank is not a different size but from my understanding the standard transmission cranks have a machined end and the automatic transmissions crank don't because they don't need to be. a 360 from a 90 might work but you would most likely have to switch intakes and distributors.
Old Jun 4, 2011 | 09:09 PM
manyhobbies's Avatar
manyhobbies
There "might" be a hole that you just need to add the pilot bearing to. I believe in the older motors that was the case.
Old Jun 4, 2011 | 11:23 PM
wontacceptthis's Avatar
wontacceptthis
Well. Is your current engine a magnum, or tbi?
Old Jul 18, 2011 | 03:11 AM
92w150ram's Avatar
92w150ram
current motor is a tbi. still havent found the right motor for it
