1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Has anyone put a A-518 or one of the RH series of transmissions in there truck. Was it worth it, noticeable mpg improvement? How much fabrication for the trans cross-member?
Is it worth it? That would depend on how and where you drive the truck. I don't do much highway driving or even flat land driving so it would not pay me to swap. Here is a good article that might answer some of your questions. Be aware that the gear ratios listed for the overdrive have an extra zero and should read .69 to 1.
I wouldn't even consider that. The A-500 is considered a light duty transmission. It was primarily used behind 6 cylinders and small V-8s in smaller or lighter vehicles.
