Looking for help with my old dodge d100
Old Jul 29, 2011 | 04:09 PM
stangrider's Avatar
stangrider
Default Looking for help with my old dodge d100
I'm having trouble removing the vent wing assembly from the door of my '76 Dodge D-100. I've got all the fasteners removed that I can find, but I still cant get it to come out of the door. Any suggestions? Any help would be appreciated.
Kerry
Old Jul 29, 2011 | 07:41 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF. First, before anything else, please read this.
I will move this to the 1st gen section (pre-1994 Rams).
Old Jul 30, 2011 | 09:40 AM
SEAL's Avatar
SEAL
Mine has a screw at the front of the vent window frame and one at the bottom of the main window front channel that is part of the vent window frame. The main window on mine had to be lowered and moved to the rear to gain room to pull the vent window frame. The main window channel weather striping at the top must also be removed. These can be stubborn and do require patience.
Old Jul 30, 2011 | 01:53 PM
stangrider's Avatar
stangrider
First, thanks for the welcome jasonw, and my apologies for posting in the wrong forum, I thought I was in the 1st-gen forum when I posted this. Second, thank you Seal for responding. I had all that done, what turned out to be the problem is that the tip of the screw that holds the vent wing swivel mount to the frame was catching on the edge of the inside of the door frame.
