Help: No brake lights
Old Sep 13, 2011 | 08:50 PM
Alouie's Avatar
Alouie
Default Help: No brake lights
Just found out that my brake lights dont work, but the turn signals do and the running lights work also. Didn't see any shorts and the bulbs are good. Any ideas?
Old Sep 13, 2011 | 11:09 PM
crazzywolfie's Avatar
crazzywolfie
i would have to guess your problem is with the turn signal switch or the brake light switch since you say the turn signals work and they use the same bulb as the brake lights.
Old Sep 14, 2011 | 12:29 AM
Dodgeman707's Avatar
Dodgeman707
I had this same issue couple years ago on my 91 it was a blown fuse lol I was so lost when it happened
Old Sep 14, 2011 | 07:26 AM
SEAL's Avatar
SEAL
Without knowing the year specifics are harder to give, but I would check for power in and out of the brake light switch. This will cut your trouble shooting in half immediately and send you in the right direction.
Old Sep 14, 2011 | 11:51 AM
Alouie's Avatar
Alouie
It's a 85 with the 318. I just looked at the switch. The white wire going to the connector has been stripped a little and is exposed. Then I saw one of those braided ground wire. Is that white wire supposed to be grounded where it has been stripped?
Old Sep 14, 2011 | 12:38 PM
SEAL's Avatar
SEAL
The brake switch is a pass thru. Power in one wire that is passed thru to the other wire when you step on the peddle. No ground is involved. If you touch the two wires together the brake lights should come on so you can test the switch even without a meter.
Old Sep 14, 2011 | 02:10 PM
Alouie's Avatar
Alouie
This is what I am talking about, The whole wiring on the truck seems to be jimmied. The switch seems to be working properly, will test when I find my light
Old Sep 14, 2011 | 05:06 PM
Alouie's Avatar
Alouie
So there is no power going to the switch. Just got to find out which wire is to the power and where it goes
Old Sep 15, 2011 | 10:52 AM
SEAL's Avatar
SEAL
Check your fuses. You can jumper 12 volts to each wire at the switch to find out which one goes back to the brake lights and which one goes to the fuses. Do your hazards work? they are usually on the same fuse.
Old Sep 15, 2011 | 02:07 PM
Alouie's Avatar
Alouie
The hazards make the clicking noise on the inside but nothing flashes but when I pulled the fuse only one of prongs I'n the panel lit up with the test light
