Yet another problem
Old Sep 19, 2011 | 04:19 PM
HAzMAT09's Avatar
HAzMAT09
Default Yet another problem
I got the idle straighted out and now she purrs but every time I kick the heat on the whole truck shuts down, any ideas?
Old Sep 19, 2011 | 10:16 PM
89ram150's Avatar
89ram150
My guess would be vacuum related. All the hvac stuff is run off of vacuum. Could be a leak behind the dash or where the lines go through the firewall.
Old Sep 20, 2011 | 07:31 AM
SEAL's Avatar
SEAL
Does it shut down at speed or only at idle? Does it shut down slowly or like you just hit a kill switch?
Old Sep 20, 2011 | 01:01 PM
HAzMAT09's Avatar
HAzMAT09
it will run for about 15 seconds and then nothing. and at running speeds its about 10 seconds.
Old Sep 20, 2011 | 03:06 PM
SEAL's Avatar
SEAL
That tells me it is not vacuum. 91 is a TBI. Look down inside the throttle body and see if the fuel shuts off or slows down just before it shuts off. This should tell you if it is a fuel problem or electrical. Does it shut down slowly or like you just hit a kill switch? Does it restart immediately after it shuts off and if so is it hard to start or does it start right up?
Old Sep 20, 2011 | 03:29 PM
89ram150's Avatar
89ram150
I agree with all that, but it's odd how the heater would affect any of that. Maybe on a '91 it's different, but I didn't think there was anything electric, other than the blower motor, involved in operating the heater.
Old Sep 21, 2011 | 01:32 AM
HAzMAT09's Avatar
HAzMAT09
Im thinking a fuse might have blown. Ive been working alot with the electrical system and charging system since when I bought it the wire harness was a mess. Someone was using it for a plow truck and I have all kinds of splice jobs under the hood. I even found a piece of lamp cord under there. So Ive been trying to run back all the wiring and clean it a bit.
Old Sep 21, 2011 | 07:39 PM
HAzMAT09's Avatar
HAzMAT09
So i stripped everything down to the standard wire harness and re-grounded everything. I also checked all the fuses and all were fine. Anyone have any ideas?
Old Sep 21, 2011 | 08:45 PM
89ram150's Avatar
89ram150
And the only thing that causes it to die is turning the heat on?
Old Sep 21, 2011 | 10:32 PM
HAzMAT09's Avatar
HAzMAT09
seems that way, Im afraid to try anything else. But she runs in all gears pretty well and since the tune she has a bit more pep, but as soon as the heat goes on the truck goes off. I thought maybe a vacuum leak? But how to check that and where to look?
