Carburetor Fuel Leak - Carter Thermo-Quad
Old Oct 27, 2011 | 02:47 PM
pumbu's Avatar
pumbu
Default Carburetor Fuel Leak - Carter Thermo-Quad
The Carter Thermo-Quad carburetor, model 9375S, for my 1982 Dodge Ram D350 318 engine is leaking. I am not sure it if needs a total rebuild, or if a part will do. I have attached a photo showing where the drip is. Can someone who knows more about carburetors than me, which is likely everyone on this forum, tell me what I should do? Thanks!
The drip is:
Overhead shot of the carburetor:
Old Oct 27, 2011 | 06:29 PM
1986JEEP's Avatar
1986JEEP
A reduild mite fix it from my research is that it is a common problem. So if i was you i would look for i defrient carb.
Old Oct 27, 2011 | 06:50 PM
aje1127's Avatar
aje1127
years ago i ran a couple 360,s with this carb. throttle shaft always seemed to leak from wear. this may be your problem,or the phenolic type plastic the body is made out of also seemed to warp and cause gasket leaks.
Old Oct 27, 2011 | 07:02 PM
pumbu's Avatar
pumbu
Thanks! What would be a good replacement that is reliable? I have done some research and there are some issues out there with rebuilt carburetors. Which rebuilt carburetors are reliable? --Thanks!
Old Oct 28, 2011 | 06:10 AM
aje1127's Avatar
aje1127
well personally i always used the holley #4160 with vac. secondaries and electric choke for reliability,easy to tune and parts are easy to get new.
they flow 600 cfm. its a square bore carb. if you want a spread bore carb,i would suggest the holley #4175(i think) its polished alum. it has solid body with no gaskets below the fuel level so less chance of it ever leaking. i dont remember what the cfms are but a few years ago i ran this carb on a 440,then removed it and ran it on a 360 both ran good with it.
hope this helps,this is just my opinion.
you can do more research on this to see what you prefer,but new carb is your best bet. good luck
Old Oct 28, 2011 | 07:24 AM
pumbu's Avatar
pumbu
Thanks for all the insight. Research indicates that there are some poorly rebuilt carburetors out on the market. Which rebuild venders are recommended?
Old Oct 29, 2011 | 09:07 AM
aje1127's Avatar
aje1127
IMO, i dont know of names of carb rebuild companys. i have always bought a new performance carb from holley. a new holley isnt much more than a rebuilt factory replacement. its your choice. good luck
Old Oct 29, 2011 | 01:03 PM
Wombat Ranger's Avatar
Wombat Ranger
I would run a 600cfm edelbrock performer. I have a 600 cfm carter AFB on mine, which is an older version of the same, and it is great. Reliable, very simple to rebuild, and works well with a smaller motor like a 318. Good luck whatever you do.
