1984 Dodge power ram help
Old Feb 1, 2012 | 03:47 PM
Didger78's Avatar
Didger78
Default 1984 Dodge power ram help
I have a 84 Dodge w-150,v8,4wd,5.2 L,318. My truck keeps stalling when i give it gas and wont idle right.i put three diffrent carbs on it but it didnt help. i put new manifold gaskets on it. any suggestions on what i should do or what the problem is? thanks for your help.
Old Feb 5, 2012 | 04:06 PM
lxman1's Avatar
lxman1
Site Moderator
Where is the timing set at? Is the advance working in the distributor?
Old Feb 5, 2012 | 09:32 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Also, have you checked for other vacuum leaks or misrouted vac lines
Old Feb 5, 2012 | 10:10 PM
SEAL's Avatar
SEAL
More info please. Is it automatic or manual? Will it idle on its own even if it is rough? Does it back fire thru the carb when you give it gas before it dies? What carb is on it and have the three carbs been new, rebuilt, or just used? Have you set the mixture screws? Was it doing this before the first carb change? Let us know about where the timing is set.
Old Feb 6, 2012 | 06:50 PM
tooltime's Avatar
tooltime
Could the spark plugs or wires etc cause the problems?
Old Feb 12, 2012 | 02:50 PM
Woodbeef's Avatar
Woodbeef
Have you pulled the distributor and looked at it? is the vacuum advance working correctly? What about the timing?
Old Feb 12, 2012 | 07:32 PM
Didger78's Avatar
Didger78
automatic tranny,idles good but dies after 10 minutes when cold, didnt backfire threw carb,2 of the carbs wherer re manufactured from holly-they were 2 barrels and where put on my truck and adjusted right.i cant really check the timing because i sent the carbs back. my buddy told me to buy a seprate adjustment plate that the carb sits on, but i havent found any yet.
Old Feb 12, 2012 | 07:35 PM
Didger78's Avatar
Didger78
it has all new spark plugs, wires, distributer, rotor and cap. vac was good had it on a pressure gage. i put new gas lines and fuel sending unit
Old Feb 13, 2012 | 06:21 AM
SEAL's Avatar
SEAL
The timing we are all talking about checking is the ignition timing that is done using a timing light. Was it doing this before all of this work was done or has it started since the work began? Let us know about where the ignition timing is set.
Old Feb 19, 2012 | 01:47 PM
Didger78's Avatar
Didger78
well it does not run at this time so i cant check the timing. it started stalling then i changes all the parts but it didnt help or made it worse.
