1990 W150 "Y" Power steering issues
Old Mar 20, 2012 | 08:01 PM
crazzywolfie's Avatar
crazzywolfie
you don't have to replace the belt. you just need to tighten it which should not be to hard. should just have to loosen 1 14mm bolt and pull pump till belt is tighter and then tighten the bolts again.
Old Mar 20, 2012 | 08:54 PM
BigGreenBeastly's Avatar
BigGreenBeastly
Awesome! Thanks everyone I'll try tightening it first.. I was actually just looking at it and couldn't find the tensioner.. Do I really have to take the fan off and alternator to get the PS belt off? I'm gonna try tightening it for now but for future reference.. I know I know I need a haynes manual
Old Mar 20, 2012 | 09:18 PM
crazzywolfie
no but you do have to take all the other belts off. the alternator and power steering pump act as there own tensioner which is a good thing. the newer serpentine belt system used on almost every new vehicle sucks.
Old Mar 21, 2012 | 02:59 PM
BigGreenBeastly
Ok, Thanks.. I'm gonna tighten the belt after work so i'll let you know how it goes!
Old Mar 23, 2012 | 09:35 AM
BigGreenBeastly
Ok, so there was no tightening the belt... It was as tight as you could get it and still skipped. So I went out and got another belt and put it on which resulted in success! Power steering works 100% now. Guess it's on to the next "to do" item. Thanks for everyones input!
