No spark & no fuel.
No spark & no fuel.
My truck, Dodge Dakota is 1993, 3.9l with automatic transmission, 95000 miles, Before I had this problem, the truck started then stalled and shut off. Now it's been completely dead, cranking but no starting.
I fixed the corroded splice under the Relay Box along with new relays, changed Crankshaft sensor, camshaft sensor, distributor cap & rotor and the coil, & ignition coil, last & not least the battery.
However, with all mentioned above, I still have no spark & fuel. My concern should "ECU or computer board" has been bad? I think about change it? Any idea or suggestion? I don't want to give up just yet.... Spending too much time & emotion into my truck, not counting the money yet.
Anyway thank you all in advance for the up coming input, any of them are greatly appreciated.
