slipping transmission
Old Jun 18, 2012 | 09:41 PM
crazzywolfie's Avatar
crazzywolfie
that could also be an option. almost seems a bit cheap. i think before you order a transmission though you should confirm that it is a 46RH and not 46RE like they say in the title.
Old Jun 18, 2012 | 09:47 PM
SEAL's Avatar
SEAL
Change the fluid and filter and adjust the bands before you go to all the trouble you are talking about. This may very well be all that is needed since you have caught it early.
You can not flush the newer torque converters while they are on the vehicle. The old torqueflite converters used to have a drain plug. You can flush the lines and cooler with the proper equipment.
Old Jun 18, 2012 | 11:07 PM
xjarhead69's Avatar
xjarhead69
46re was not used till 1996. Everything before 96 was still hydraulic governor re is electronic garbage, I have one.
What engine do you have? 3.9 uses 42rh and 5.2 and 5.9 use 46rh
see here https://dodgeforum.com/forum/2nd-gen-ram-faqs-diys-and-how-tos/292409-what-automatic-transmission-do-i-have.html.
There is wealth of info in the 2nd gen forum FAQ's section on these tranny's.
Also follow instructions on how to download and watch this video https://dodgeforum.com/forum/2nd-gen...8-46rh-re.html.
Also check to see if you have this and delete it also https://dodgeforum.com/forum/2nd-gen...46rh-46re.html
Lots of info in this thread https://dodgeforum.com/forum/2nd-gen...info-only.html
Dave
Old Jun 18, 2012 | 11:20 PM
xjarhead69's Avatar
xjarhead69
i am pretty sure you do not want to flush your transmission. hopefully the new fluid will help it along but you may want to start saving your money to replace it or rebuild it. the 46RH's are know for to be somewhat weak. the 93 ram charger i bought only has 212,000km on it and it has already had the trans rebuilt. you may from now on want to start your with the truck in neutral and not let it idle in park. the 46RH's do not pump fluid in park which is what causes them to fail prematurely. there is shift kits to fix these problems but yours may almost be a bit too far gone to save.
http://www.sonnax.com/system/announc...C-46-47RHE.pdf
The sonnax kit is not a shift kit. its only purpose is to fix inherent design flaws from the factory.
This explains the purpose of a shift kit http://www.allpar.com/mopar/shift-kits.html
Dave
Old Jun 20, 2012 | 10:21 PM
camd94234's Avatar
camd94234
ok so i got the filter from my local parts store and i want to adjust the bands but the haynes manual says tighten the adjuster bold to 70 in lbs or torque but does not say how many times to back it off any suggestions???? i am hoping to do this tomorrow and anything i should know what not to do and what to do wile doing this
thanks,
cam
Old Jun 20, 2012 | 10:57 PM
xjarhead69's Avatar
xjarhead69
thanks,
cam
Check this http://www.moparchat.com/forums/showthread.php?t=92947
Dave
Old Jun 20, 2012 | 11:05 PM
xjarhead69's Avatar
xjarhead69
ok so i was looking for a rebuild kit for my truck i cant find a transmission rebuild kit for a 46RH or an a518 all i can find is a 518 transmission rebuild kit or a 46re rebuild kit but i found a rebuild tranny from ebay
heres the link
http://www.ebay.com/itm/92-95-Dodge-...#ht_1863wt_754
Check here for kits here http://www.transmissioncenter.net/dodge.htm
and here http://www.transmissionpartsusa.com/Default.asp
and here https://www.wittrans.com/default.aspx?
These are all sites that guys in 2nd gen forum have used.
Dave
Old Jun 20, 2012 | 11:14 PM
xjarhead69's Avatar
xjarhead69
i can get a tranny out of a 2wd d100 i dont think it has overdrive and it has 3**** miles on it. and would my transfer case bolt on to it because if it would then i can get it really cheap and im going to buy the motor too because i might as well put the motor in mine too and just switch the fuel injection system from my motor onto the one from the d100 and have a pretty much brand new motor and transmission
The biggest difference would be the extention houseing's d100(2wd) looks like this
And the w100(4wd)looks like this
You would have to swap extention housing's.
Dave
Old Jun 21, 2012 | 07:02 AM
sls001's Avatar
sls001
Originally Posted by xjarhead69
The biggest difference would be the extention houseing's You would have to swap extention housing's.
Dave
There is more to it than that...the housing holds the OD section of the trans so it is a complete tear down and swap then reassemble the trans.
Old Jun 21, 2012 | 09:24 AM
wontacceptthis's Avatar
wontacceptthis
http://www.lucasoil.com/products/dis...iid=29&catid=2
