transfercase drop??
transfercase drop??
i talked to a person that just got out of school he has been at uti for 2 years doing all kinds of different courses and we went for a ride in my truck today and he said that i needed to drop my transfercase because my driveline angle is too much.. what should i do because i have noticed that i have slight vibrations but not to bad after lifted my truck so my main question is where could i find a kit or spacers to drop my t-case.
thanks,
cam
thanks,
cam
If you looking for a "direct" bolt-in kit specific for Dodge trucks they don't make them, you will need to make one up yourself.
You should measure our drive line angles and check you u-joints. You can shim the rear axle to adjust the pinion angle but you shouldn't need to with only 5".
Again, you can't do a transfer case drop as it will only make the angle on the front drive shaft even worse.
