Big Block swap
Old Sep 1, 2012 | 03:27 PM
Dodge360mag's Avatar
Dodge360mag
Default Big Block swap
Hi ive got a 1985 dodge ram 100 4x4 that has a 318 and a 3 speed tranny which im not sure what it is. Id like to pull the 318 and put in a 440. Is it possible to mount a 440 up to the stock tranny? If not id like to put in a 727 trans but i dont know if it will mount to my stock transfer case. Does anyone know if it will or not. also does anything else have to be changed besides motor mounts. if there is a way to keep my tranny i have now please let me know. Thanks.
Old Sep 1, 2012 | 03:34 PM
1986JEEP's Avatar
1986JEEP
No you will need a big block trany, truck motor mounts for the bb. The bb trany will bolt up to your t-case.
sls001's Avatar
sls001
You will need a big block 727 (you currently have a 727 but will not fit). To mount your current transfer case you will need to swap the tail housing from the BB trans to the SB trans which entails an entire tear-down and rebuild.
You will need a trans, all the engine brackets, exhaust, a different brake booster, extend a couple wires. You need the specific BB engine mounting brackets and the truck style oil pan and oil pick-up tube and headers as well.
http://bouchillonperformance.com/BPEtruckKit.asp
Old Sep 1, 2012 | 03:36 PM
sls001's Avatar
sls001
His truck will have the np208 transfer case. A BB 727 will only bolt up to a NP203 so he will have to swap tail shafts as they will not bolt up to the 208 (or 205 or 241)
Old Sep 3, 2012 | 07:22 PM
Dodge360mag
Default Swap
Is there any way to make the big block bolt up to the small block tranny like a different bellhousing? Ive never done any motor swaps so this is new to me thanks
Old Sep 3, 2012 | 07:28 PM
crazzywolfie's Avatar
crazzywolfie
not really. any adapter would make you have to move your transmission/transfer case back. then you would also have to get custom drive shafts made.
Old Sep 3, 2012 | 07:50 PM
sls001's Avatar
sls001
Yes with a JW Ultrabell ...you need to cut the old "bell housing" off from the trans and remove the front pump bolts and bolt it one on...http://www.racewithjw.com/
I'm using one to bolt an A518 to a 505 BB stroker. This will keep the trans in the same place, no mount issues etc.
Old Sep 4, 2012 | 06:29 PM
Dodge360mag
Default Bell housing
Why would i have to cut the bellhousing off. It wouldnt just unbolt. And the ultra bell is a GM product isnt it? It only metioned the powerglide on the site nothing about dodge .
Old Sep 4, 2012 | 06:37 PM
sls001's Avatar
sls001
The bell housing doesn't unbolt from a 727...
The ultra bell is made by the company I provided you the link to. Has nothing to do with GM.
You need to look through their catalog to get the part number...it is also sold on Jegs and Summit
http://www.summitracing.com/search/M...ord=ultra+bell
Old Sep 5, 2012 | 10:07 AM
1986JEEP's Avatar
1986JEEP
I did the swap and it all bolted up no prob at all and i have a 208 t-case and 727 trans.
