Rustoleum Paint Job Finished
Old Sep 16, 2012 | 03:12 PM
crazzywolfie's Avatar
crazzywolfie
Originally Posted by pumbu
2. Crazzywolfie I noticed it looks like you have aftermarket rear lights. Did you get a good seal? Mine seem to have a little gap at the top where the plastic meets the metal of the truck and water can get in. Any suggested remedies for getting a better seal?
the picture i posted had factory style tail lights. the new aftermarket tail lights are cheap. i got one on my 81 but it is on the that the box is damaged so it is hard to say how well it fits. it does seem to fit better than the factory with the way the bed was hit. i have been meaning to try one in the undamaged side but have not got around to it yet.
Old Sep 16, 2012 | 04:16 PM
tooltime's Avatar
tooltime
My truck is silver with red inside (1988) and is peeling etc. I want to paint mine or check into how much it would be. I have found out about a paint that is John Deere Blitz Black,1 gallon is $25.00. Google it if interested. I wanted to paint it blue with a white top but red inside. I bought some spray paint this weekend but don't know when/if i will. If anyone is interested check out www.autobody101.com
Old Sep 16, 2012 | 09:08 PM
wontacceptthis's Avatar
wontacceptthis
I used "amazing e-6000" adhesive for the emblems on the last paint job, along with foam camper tape. I just cut the tape to size, and put the glue on each side. It lasted two years perfectly, with no problems at all. This time I used camper tape again but with regular old super glue. If this fails, I'm going back to the e-6000.
Old Sep 17, 2012 | 08:00 AM
pumbu's Avatar
pumbu
Thanks! I will track down some e-6000, I have not used this before.
Old Oct 9, 2012 | 07:21 PM
durec's Avatar
durec
Default Looks Good
What would be your advice on sanding? My 88 has a bad 2nd paint job on it where the painter didn't prepare the surface of the original color well...now it pops off everywhere. I thought about doing this myself but I didn't know what grit to use or what type of sander works best
Any advice?
Thanks
Old Oct 9, 2012 | 10:52 PM
wontacceptthis
I finished up with a 600 grit I believe. I started out with a 40 on the rough body filler I layed down. Having a sander made life much easier. I used an old craftsman orbital sander, and was satisfied with it. It was a little big to get the smaller spots with, though.
Old Oct 10, 2012 | 08:55 PM
pumbu's Avatar
pumbu
Any advice?
Thanks
I used a Porter Cable DA polisher/sander with anywhere between 400 and 800 grit to remove old paint and rust; I would spray the area with water from a spray bottle as I went along. I too had some peeling from where I did some spot painting last year and did not prep the surface too well. For heavy rust I used a Milwaukee grinder with a wire brush head. After hitting all the obvious spots then I made sure to sand everywhere else to rough up the paint.
Old Oct 11, 2012 | 01:21 PM
durec's Avatar
durec
Default Thanks
appreciate it
Old Oct 11, 2012 | 01:56 PM
nerog's Avatar
nerog
Man, that looks pretty good! Although I love shiny paint, there is just something rugged with imperfect, not 100% smooth paint on these old trucks. Just gives it a more age correct look, imo.
Old Oct 11, 2012 | 07:53 PM
pumbu's Avatar
pumbu
Thanks! I agree. When you drive a 30 year old truck that gets 9 miles to the gallon, you don't need a prissy look.
