smelling fuel
Old Nov 3, 2012 | 03:21 PM
Josh17's Avatar
Josh17
Default smelling fuel
This only happens while driving, and I wasn't really concerned about it until now, but when driving my truck for awhile I notice the smell of fuel in the cab, it gets rather bad after driving for a while (enough to give me a headache). So my question is: Is what i'm smelling unburnt fuel from a misfire? or a fuel leak, maybe i should replace my fuel filter?
Old Nov 3, 2012 | 04:17 PM
crazzywolfie's Avatar
crazzywolfie
have you looked for any leaks under the hood or under the truck?
Old Nov 3, 2012 | 04:22 PM
SixGun's Avatar
SixGun
I replaced all the rubber lines on my truck and there was a lot of dry rot.
Old Nov 3, 2012 | 04:25 PM
crazzywolfie
i would also wonder if the charcoal canister is missing. i know mine is and when i have a fairly full tank you can smell gas.
Old Nov 3, 2012 | 07:21 PM
Josh17's Avatar
Josh17
no but i will tomorrow, i can only smell the gas after it has ran for a while and i have never spotted any marks on the ground that would indicate a leak, i will have to look for the charcoal canister as well.
Old Nov 3, 2012 | 08:01 PM
crazzywolfie
if you have one you will notice it on the passenger side wheel well.
Old Sep 3, 2013 | 03:34 PM
reichard01's Avatar
reichard01
Default gas smell
Did you ever find your gas smell issue? I'm having the same problem.
Old Oct 24, 2013 | 02:20 AM
Josh17's Avatar
Josh17
well I never found out why I was smelling gas. That is mostly because I crashed and haven't driven it much since. I slid on ice and 360ed into a speed limit sign one icy morning on the way to school Hit right dead center on the driver's door, bent the floor up, put a nice kink in my dual exhaust, and shifted the whole cab to the right. Still runs like a top though! I used her to pull a friend out of some mud. Right now though she is sitting in the backyard with a tarp over her. Got a new 1999 dakota for my daily now.
Old Oct 24, 2013 | 07:33 AM
tooltime's Avatar
tooltime
Mine smells only in the am for a min or so. It smells only when i am stopped and truck is a 1988 with a 3.9
Old Oct 24, 2013 | 07:44 AM
reichard01's Avatar
reichard01
Found out mine was a leak in the fuel pump. Only found it her I left the motor running and looked under the hood.
