tire size
Old Nov 20, 2012 | 12:29 PM
Sniper X's Avatar
Sniper X
Originally Posted by tarheelboy
Some different opinions here. One with a lower truck than mine that had no problems with 33x12.5's and another with 3 more inches of height than mine that had scrubbing with 33x12.5's.
Maybe I'll just go with 33x11.5's.
yeah, all trucks can be different as can the offset on the wheels they all run so that is probably it. I like a smaller offset on my off road wheels than a lot of people go with which is probably why mine didn't rub. PLUS my truck sits kinda high for a stock truck and it MIGHT not be stock height. It might have a 2in lift. I had 33 12.5s and am now on 31 10.5s and I notice NO DIFFERENCE in off roading, but do notice I have quicker handling, better gas mileage, and never wonder if I am going to rub in a high angle situation. I also only use 8in wide wheels where most go 10s or 12in with off road tyres.
Old Nov 20, 2012 | 12:43 PM
tarheelboy's Avatar
tarheelboy
I don't do much off roading. Not many place to do that around here. My off road excursions will be on the beach fishing so there isn't a concern with extreme angles. Honestly I wanted to go bigger on tires for looks but I don't want to have to trim the wheel wells to keep from scrubbing just to have a more aggressive stance.
Old Nov 21, 2012 | 10:54 AM
Sniper X's Avatar
Sniper X
Isn't there a wider 31 than 10.5 then? If height isn't a need, then I'd see if someone makes a 31x12.5 or even little wider for the sand It is the height combined with the width that may get you in trouble.
Old Nov 21, 2012 | 04:24 PM
tarheelboy's Avatar
tarheelboy
I haven't thought of that. I just don't like the empty space in the wheel wells I guess. I like it when they look full. Personal preference I guess. My neighbor has a 2006 with a 6" lift and 285's on it. You can see the shocks and everything. I just don't like the way it looks. But you make a good point about the added width for the sand.
Old Nov 23, 2012 | 10:43 AM
rabbit62's Avatar
rabbit62
Standard rule i follow on full size rams for tires up to 12 wide is 2 in lift for 31 in tires 4 in lift for 33 and 6 for 35s anything less and they will rub either turning or flexing on the back edge of the fender
Old Nov 24, 2012 | 04:04 PM
Sniper X's Avatar
Sniper X
In that case, I am guessing my truck isn't stock like I thought. It had 33 12.5s on it right before I got it, went back to 31 10.5s and they don't come close to rubbing even at extreme angles and compression.
Old Nov 24, 2012 | 04:51 PM
SEAL's Avatar
SEAL
I have run 31x10.5s since the original tires wore out with no lift. Even with tire chains on all 4 wheels there is no contact.
Old Nov 25, 2012 | 07:11 AM
rabbit62's Avatar
rabbit62
All trucks are different but on the older power wagons and first generation rams 31s will fit under stock height but 2" lift makes it safer 33s need 4 " because of how narrow the wheel well is in my experience
Old Nov 25, 2012 | 07:13 AM
rabbit62's Avatar
rabbit62
what year truck is it?
Old Nov 26, 2012 | 10:57 AM
Sniper X's Avatar
Sniper X
1991 W150 Power ram 150, here it is.
