Steering wheel upside down
Old Dec 27, 2012 | 11:46 PM
Comrade General's Avatar
Comrade General
Sure, Ill take one tomorrow
Old Dec 29, 2012 | 02:14 PM
Comrade General
Here the drag link
Also heres my driveshaft. It was extended for the conversion, just seems a little odd.
Old Dec 29, 2012 | 03:44 PM
sls001's Avatar
sls001
Default Adj. Drag Link
You could use an adjustable drag-link. I'm surprised that your D60 didn't come with one.
I'll say it again; you would be amazed at the difference that cross-over steering will do for your steering\handling.
What is odd with you drive shaft? I'm getting ready to have my front one shortened but I'm thinking about having a new one made for the rear instead of having it lengthened.
Edit: here is the one I just removed
Old Dec 29, 2012 | 09:25 PM
Comrade General
How it goes big to little like that. I just didnt know if that was normal or not.
Ill have to look into getting cross over then
Old Dec 29, 2012 | 11:56 PM
SilverRam_01's Avatar
SilverRam_01
Adjustable drag link is the key. By having a steeper angle, it in essence made it shorter, meaning the pitman arm had to turn farther one way for the ends to connect, making the wheel off-center.
Old Dec 30, 2012 | 06:27 AM
SEAL's Avatar
SEAL
The driveshaft is like that because someone has installed a slip yoke eliminator kit. It moves the slip yoke from the T-case to the drive shaft.
Old Dec 30, 2012 | 08:11 AM
sls001's Avatar
sls001
It wouldn't have had a slip yoke on the x-fer case. Dodge 4x4's had a fixed yoke on the transfer case and slip splines built into the drive shaft. I can't say this is the case for all years but but all the ones I've had and back to my son's 83 RC all did.
Old Dec 30, 2012 | 08:16 AM
sls001's Avatar
sls001
That is normal for the drive shaft.
As far as the cross-over; you can get a good kit that fits with no issues here:
http://www.offroaddesign.com/catalog...0crossover.htm
You will need to move your steering box to the 2wd position on the frame which is straight forward, simply remove the steering box then the bracket from the back of the box and bolt it back to the frame. I do however recommend you either install one of the kits that Jim over on RCC makes or one of the factory steering box braces.
http://ramchargercentral.com/jungles...rame-supports/
Here is a "How To":
http://ramchargercentral.com/jungles...ank-you-eric!/
Old Dec 31, 2012 | 08:06 PM
Comrade General
Thanks for the info yall.
And good links too. That x-over aint cheap though. Itll be another future project
Old Apr 4, 2013 | 01:25 AM
Comrade General
Digging this up again.
Decided Im gonna go ahead and do this insead of getting an adjustable drag link. One of my buddies did it and he really liked it so now I just asked Jungle at RCC about getting the reinforcement bracket. Just hopefully I will find somewhere than can weld it up for me since I cant. most likly have to get the whole thing done somewhere
EDIT
Just found this brace for the same thing. http://www.dodgeconnection.com/catal...66/4541374.htm
Anyone know anything about it or used it? Would be easier for me since no welding required
