power rebuild
Old Dec 23, 2012 | 11:44 PM
MikeBigRedDodge's Avatar
MikeBigRedDodge
Default power rebuild
So, i have a leaking head gasket. I said screw it, time to rebuild. I ordered flat top pistons, eagle steel stroker crank, roller lifters, roller rockers, beam connecting rods, chrome moly rings, getting heads done, stock intake(maybe), all mew bearings, high volume oil pump. Now camshaft. I have an 81 with an automatic 360, i know nothing about chosing cams. Cananyone point me in the right direction? I wanna male decent power without having to put in a stall converter.... That sucks.thank you very much in advanced.
Old Dec 24, 2012 | 09:27 AM
sls001's Avatar
sls001
Call Hughes Engines: http://www.hughesengines.com
Make certain you use the correct valve springs, you will also need to get the correct push rods.
Old Dec 24, 2012 | 10:12 AM
cruzer55's Avatar
cruzer55
Need motor size,I have a few part # for cams-cranks and valve train ?What kind of HP and torque do you want to make
Old Dec 25, 2012 | 12:17 AM
JGC403's Avatar
JGC403
A lot of guys on my Jeep forum are using this cam in their 408, Comp cams 20-604-9. But I'm thinking of replacing it with a Hughes Cam.
Old Dec 25, 2012 | 08:16 PM
MikeBigRedDodge
Well, with the stroker, flat top pistons, full roller engine, i wanna make about 400-450 horses. If thats reasonable.
Old Dec 26, 2012 | 12:59 PM
JGC403's Avatar
JGC403
And a good set of headers, intake, and carb you should be able to.
Old Dec 26, 2012 | 02:36 PM
beakerztoyz's Avatar
beakerztoyz
Have you thought about using aftermarket aluminum heads? A friend of mine has edelbrock heads on his 360, and aftermarket heads aren't as pricy as you might think
Old Dec 26, 2012 | 03:34 PM
sls001's Avatar
sls001
It all depends on what the OP is going to use the truck for. If he wants hi-performance (drag racing, etc) then the Edelbrock heads are ok but need plenty of work out of the box to get them to flow. Which, after purchasing the heads you need another $500-up in porting, etc. For just a strong running daily driver stock heads should work fine. A couple other options: Hughes Iron Rams or Indy\RHS heads.
This is the same with camshaft selection - vehicle usage, trans, gears, etc
To the OP: you will also need to be concerned about compression ratio. You said you ordered "flat-top" pistons...pay attention to the piston spec's and your combustion chamber size.
Old Dec 26, 2012 | 03:52 PM
beakerztoyz
my point about the edelbrock heads was not so much that they are the best aftermarket heads, but that in order to push 400 or 450 hp like the op said he wants to it might be easier and cheaper to just bolt on a set of aftermarket heads than to have a stock set machined
Old Dec 26, 2012 | 04:38 PM
sls001's Avatar
sls001
But as I mentioned he would still need to have a good bit of work done on those heads to get them to flow properly as well as change out the springs for whatever cam he is using. The Edelbrock heads have good potential but out of the box they are not that good of a head.
The Indy\RHS heads from IMM Engines is actually a better deal than the OOTB Edelbrock's:
http://www.immengines.com/rhsheads.html
